I want to find see if it has a vol control Part nubmer 63-1123 in it.
Bob E.
:http://cgi.ebay.com/Vintage-Zenith-Holiday-radio-Realistic-long-life-tubes_W0QQitemZ220189891683QQihZ012QQcategoryZ38034QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
:I want to find see if it has a vol control Part nubmer 63-1123 in it.
:Bob E.
Try emailing Mark Oppat to see if he may have the control you need:
moppat@comcast.net
As Doug said, why cannibalize the set if a replacement equivalent is available :)
:Bob: Zenith Model A-400, 1957. Estimated value, per Slusser, 6th edition, is $40-45. Is the volume control all that you're seeking? I think it would be a shame and expensive to canabalize that set.
:Doug
::http://cgi.ebay.com/Vintage-Zenith-Holiday-radio-Realistic-long-life-tubes_W0QQitemZ220189891683QQihZ012QQcategoryZ38034QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
::I want to find see if it has a vol control Part nubmer 63-1123 in it.
::Bob E.
:Bob:
:Try emailing Mark Oppat to see if he may have the control you need:
:moppat@comcast.net
:As Doug said, why cannibalize the set if a replacement equivalent is available :)
::Bob: Zenith Model A-400, 1957. Estimated value, per Slusser, 6th edition, is $40-45. Is the volume control all that you're seeking? I think it would be a shame and expensive to canabalize that set.
::Doug
:::http://cgi.ebay.com/Vintage-Zenith-Holiday-radio-Realistic-long-life-tubes_W0QQitemZ220189891683QQihZ012QQcategoryZ38034QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
:::I want to find see if it has a vol control Part nubmer 63-1123 in it.
:::Bob E.
:Bob:
:moppat@comcast.net
::Doug
:::Bob E.
:Bob:
Mark's website is www.oldradioparts.net. Good luck.
Allan
::Bob:
::Try emailing Mark Oppat to see if he may have the control you need:
::moppat@comcast.net
::As Doug said, why cannibalize the set if a replacement equivalent is available :)
:::Bob: Zenith Model A-400, 1957. Estimated value, per Slusser, 6th edition, is $40-45. Is the volume control all that you're seeking? I think it would be a shame and expensive to canabalize that set.
:::Doug
::::http://cgi.ebay.com/Vintage-Zenith-Holiday-radio-Realistic-long-life-tubes_W0QQitemZ220189891683QQihZ012QQcategoryZ38034QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
::::I want to find see if it has a vol control Part nubmer 63-1123 in it.
::::Bob E.
:Bob: Zenith Model A-400, 1957. Estimated value, per Slusser, 6th edition, is $40-45. Is the volume control all that you're seeking? I think it would be a shame and expensive to cannabalize that set.
:Doug
::Bob E.
