question on how to read tube diagrams
1/7/2008 5:06:43 PMwade Epler
Hey folks-
My radio has a 6u5 eyeball tube in it, and it appears the previous owner grabbed the wiring harness, took a hard pull, and ripped every wire out of the socket. I've replaced the wiring, and now I just really need to know where each wire goes to each pin on the tube. I see the 6u5 tube diagram on this site, but I'm not sure of how to orient the tube in order to know the pin order-do I face the pins out towards me, or flip it around and treat my monitor as a tube socket? This is for a zenith 8s463 by the way, and I've recorded the original color codes for the wires leading up to the socket if that is of any help.
thanks,
Wade
1/7/2008 5:12:29 PMqfoin09
usually the pin diagrams are bottom views of the tube (i.e. pins facing you)
:Hey folks-
: My radio has a 6u5 eyeball tube in it, and it appears the previous owner grabbed the wiring harness, took a hard pull, and ripped every wire out of the socket. I've replaced the wiring, and now I just really need to know where each wire goes to each pin on the tube. I see the 6u5 tube diagram on this site, but I'm not sure of how to orient the tube in order to know the pin order-do I face the pins out towards me, or flip it around and treat my monitor as a tube socket? This is for a zenith 8s463 by the way, and I've recorded the original color codes for the wires leading up to the socket if that is of any help.
:thanks,
:Wade
1/7/2008 6:41:15 PMNorm Leal
Hi
A little to add.. Look at the bottom of the tube with large pins facing you. The large pin on the left in #1. Count clockwise until you get to the other large pin, #6.
Pin #1 and #6 are filaments. Pin #2 is plate. This one will have a 1 meg resistor connecting to pin #4. Pin #3 is grid. It goes to the AVC line. Pin #4 is target. Tied to B+, around 250 volts. Pin #5 is cathode, usually grounded.
:usually the pin diagrams are bottom views of the tube (i.e. pins facing you)
::Hey folks-
:: My radio has a 6u5 eyeball tube in it, and it appears the previous owner grabbed the wiring harness, took a hard pull, and ripped every wire out of the socket. I've replaced the wiring, and now I just really need to know where each wire goes to each pin on the tube. I see the 6u5 tube diagram on this site, but I'm not sure of how to orient the tube in order to know the pin order-do I face the pins out towards me, or flip it around and treat my monitor as a tube socket? This is for a zenith 8s463 by the way, and I've recorded the original color codes for the wires leading up to the socket if that is of any help.
::thanks,
::Wade
1/8/2008 9:35:32 AMwade epler
Okay, I've wired it up, and hey, it seems that that old 6u5 still has some life left in it! Problem is-I'm getting a negative image on it (the normally dark tuning wedge is green surrounded by a dark field)-I'm assuming two leads are switched around? Any ideas? Otherwise, the radio is running great-just fresh from recapping and is badly in need of alignment...
:Hey folks-
:thanks,
:Wade
