Once you are sure that the grid leak works as it should, start at the antenna with your generator. Inject a signal. If the tuning capacitors have trimmers, adjust each one for maximum gain. If not, you may have to adjust by other means. For starters, if the stators can be moved by loosening screws, center all stators. As an example, when I first got my Radiola 16 (Peter gave it to me), it wouldn't pick up anything. The stators weren't centered. No other means of fine tuning was provided in the set, so in order to get all stages to track similarily, I had to center the stators and then work from there.
Once you have maximum gain, connect a 10 foot or longer antenna wire and try the set out. If you still can't pull in signals well, be sure that the A battery is connected properly. Try reversing it. Strange as it may seem, the tubes and their circuitry are designed in such a way that they work best with the A battery connected one way verses another. When you think about it you'll realize that the A battery makes one side of the filament more negative than the other, which affects grid bias. Everything is designed with that in mind.
Finally, if you can't get your set to work properly, take out the 01A tubes and test them. If they test weak, run the filaments very briefly at 7.5 volts (if your tester has such a setting....if not, run at 6.3 with the LINE adjuster turned all the way up). Then, after about 3 seconds have passed, turn the filament voltage down to 6.3. Run the filament that way for at least 15 minutes. You can test to see if any improvements are being made after 5 minutes. Once you are done, the tubes should test much better. This rejuvenation procedure made a big difference in my set's performance.
Be sure that you are feeding the filaments proper voltage while operating your radio. A small decrease in voltage with thoriated tungsten filaments makes a big difference in performance. You should be reading 5.0 volts at the sockets. Of course be sure that your rheostats are adjusted properly. They are there for volume control purposes, but should be adjusted for 5.0 volts for initial tests.
:Check the 2-4 megohm grid leak resistor. It should be within that range. Inject a signal at the previous tube's plate through a .001 MFD capacitor. Connect the other end of your generator to B-. Use the resistance that gives the loudest audio signal. If you can get the signal to go through from the antenna terminal, inject there instead.
:Once you are sure that the grid leak works as it should, start at the antenna with your generator. Inject a signal. If the tuning capacitors have trimmers, adjust each one for maximum gain. If not, you may have to adjust by other means. For starters, if the stators can be moved by loosening screws, center all stators. As an example, when I first got my Radiola 16 (Peter gave it to me), it wouldn't pick up anything. The stators weren't centered. No other means of fine tuning was provided in the set, so in order to get all stages to track similarily, I had to center the stators and then work from there.
:Once you have maximum gain, connect a 10 foot or longer antenna wire and try the set out. If you still can't pull in signals well, be sure that the A battery is connected properly. Try reversing it. Strange as it may seem, the tubes and their circuitry are designed in such a way that they work best with the A battery connected one way verses another. When you think about it you'll realize that the A battery makes one side of the filament more negative than the other, which affects grid bias. Everything is designed with that in mind.
:Finally, if you can't get your set to work properly, take out the 01A tubes and test them. If they test weak, run the filaments very briefly at 7.5 volts (if your tester has such a setting....if not, run at 6.3 with the LINE adjuster turned all the way up). Then, after about 3 seconds have passed, turn the filament voltage down to 6.3. Run the filament that way for at least 15 minutes. You can test to see if any improvements are being made after 5 minutes. Once you are done, the tubes should test much better. This rejuvenation procedure made a big difference in my set's performance.
:Be sure that you are feeding the filaments proper voltage while operating your radio. A small decrease in voltage with thoriated tungsten filaments makes a big difference in performance. You should be reading 5.0 volts at the sockets. Of course be sure that your rheostats are adjusted properly. They are there for volume control purposes, but should be adjusted for 5.0 volts for initial tests.
:T.
:Did you check the other things I listed??????????????????????????????????????????????????????????????????????????????????
:T.
"The same insructions apply to these sets as to the foregoing Models 10 and 10-A, excepting that these later sets are equipped with the 3-point antenna tap switch. For most purposes this should be set at the center point. For stations below 20 on the dial, the first or nearest point should be used.The 3rd or farthest point may be useful when a very short antenna is used, or for reception of the higher wavelength stations. A change in the position of this switch requires a readjustment of the first or left hand dial."
You might want to look for a repro of the operating instructions as it gives you approximate dial settings
Try changing the antenna tap switch - located to the far left of the radio and on top of the antenna coil. Here's what's in the operating instructions for the 10B....
You might want to look for a repro of the operating instructions as it gives you approximate dial settings.
:Tom,
:Try changing the antenna tap switch - located to the far left of the radio and on top of the antenna coil. Here's what's in the operating instructions for the 10B....
:"The same insructions apply to these sets as to the foregoing Models 10 and 10-A, excepting that these later sets are equipped with the 3-point antenna tap switch. For most purposes this should be set at the center point. For stations below 20 on the dial, the first or nearest point should be used.The 3rd or farthest point may be useful when a very short antenna is used, or for reception of the higher wavelength stations. A change in the position of this switch requires a readjustment of the first or left hand dial."
:You might want to look for a repro of the operating instructions as it gives you approximate dial settings.
:How are you tuning it? You need to adjust all 3 dials as simultaneously as possible and they should all be near - but not necessarily exactly - the same reading (Station "X" may be at 35/33/37 on the 3 dials respectively). Tweak each one carefully to get the best signal - this may take a couple of trys. Make sure your tuning condensers are in sync - sometimes the knobs become loose and they can get out of sync. If that doesn't work, then look into the tuning cap cans to make sure there are no intermittent shorts, loose connections, loose plates, etc. Also check coils for broken windings and loose connections.
