Joe:
If you have a DMM or VYVM, look at the AVC Voltage and B+ before and after the trouble starts. That will split the radio into three parts, the RF, audio and power supply. Then, we will know better which direction to go looking.
Wait, wait, wait!!!!
I just noticed the tuning eye. It is a VTVM all by itself. If the tuning eye opens, the trouble is in the RF. If it stays closed and doesn't dim, you have audio trouble. For now I'll assume it is audio trouble and study the schematic and get back to you.
vtvm
:::Have swapped out all the regular paper caps on this radio. After a minute or so after being turned on the volume drops out. The station is still there and and still tuned in on the strongest point but lower volume. I need some direction. I did NOT swap out the domino caps. I have swapped out most all the resistors. There is one or two resistors that are so intertwined with the domino caps I did not risk damage in swapping them out. So I believe it is an audio circuit problem because the station stays on tune when the volume drops. I am thinking of changing out domino cap C14 along with its mated resistor R7 off of tube 6F5. Could one of these be causing my problem? how about domino cap C12 to ground off of same tube? I am also concerned with C11 and R8 off of tube 6H6. Does anyone have any input or has seen this problem before? The schematic for this radio is on this site. Thank you for your help. Just to say it again. Almost everything else has been replaced. Caps and resistors. Thank you for any input. joe
::Joe:
::If you have a DMM or VYVM, look at the AVC Voltage and B+ before and after the trouble starts. That will split the radio into three parts, the RF, audio and power supply. Then, we will know better which direction to go looking.
::Lewis
:Wait, wait, wait!!!!
:I just noticed the tuning eye. It is a VTVM all by itself. If the tuning eye opens, the trouble is in the RF. If it stays closed and doesn't dim, you have audio trouble. For now I'll assume it is audio trouble and study the schematic and get back to you.
:Lewis
:vtvm
Joe:
I am pretty sure you are right about it being an audio problem, but more than once I have chased off in the wrong direction and wasted time trying to find a problem that wasn't there. Let's make sure its broke before we try to fix it. (;>)
Joe: When you said: "and the cap is a domino cap. WHich I am told never goes." you set yourself for a bruising. Never say never about a component!! Serioulsy, the domino cap is vorking with very little strain on it, so I would be surprized if it were not good. So, let's keep an eye on things for a while. There isn't much to a 6H6 tube, but they do go bad, just like everything else.
