Thank you
Use -4 1/2 volts for the C battery. It can be 3 small flashlight cells. Some radios didn't use the C battery. In that case C- is tied to A-.
http://www.nostalgiaair.org/PagesByModel/892/M0039892.pdf
Trace battery wiring with an ohm meter if you aren't sure where they go.
:I have download the schematic and there is no info on the "C" battery. What is the voltage? Also there are no wire inside the radio to connect this battery?
:Do you know where I can get a close picture of the drawing in the back of the radio.
:Thank you
Start off with C- tied to A-, and add one 1.5 Volt cell at a time until there is no distortion in the audio. It might be that the radio will work without a "C" battery, but there will probably be distortion.
::Andre
:: Use -4 1/2 volts for the C battery. It can be 3 small flashlight cells. Some radios didn't use the C battery. In that case C- is tied to A-.
:Start off with C- tied to A-, and add one 1.5 Volt cell at a time until there is no distortion in the audio. It might be that the radio will work without a "C" battery, but there will probably be distortion.
:Lewis
:A few years ago, I got a dozen or so 3.6-V AA lithium batteries, with pigtails, from one of the surplus electronics places on the internet. Since the C battery supplies only bias voltage, no current, it will last at least for it's shelflife, which is a couple of decades for lithium cells. With their pigtails, they are perfect for most C-cell applications. 3.6V seems to be fine for most '01A radios.
:Doug
:::Andre
::: Use -4 1/2 volts for the C battery. It can be 3 small flashlight cells. Some radios didn't use the C battery. In that case C- is tied to A-.
::Start off with C- tied to A-, and add one 1.5 Volt cell at a time until there is no distortion in the audio. It might be that the radio will work without a "C" battery, but there will probably be distortion.
::Lewis
By the way, my previous source for those lithium batteries was All Electronics. But the ones they list now, @ $1.50 each, are dated 1996, so they are getting a little long in the tooth: http://www.allelectronics.com/cgi-bin/item/LBAT-49/160/3.6V_LITHIUM_BATTERY,_AA_SIZE_W_SOLDER_TABS_.html
Doug
:Doug,
:They're great for white LEDs too. Typically a forward voltage of 3.6vdc sets the current at about 20ma, which is a norm for most white LEDs. I keep a couple 3.6v nicad/nimh packs on my bench, along with a couple white LEDs on long flexible leads, for those really tight places incompatible with a regular flashlight.
:marv
:Marv, so you just strap the 3.6-V battery directly across the white LED? Without a ballast resistor? What's the forward voltage drop for a white LED?
:By the way, my previous source for those lithium batteries was All Electronics. But the ones they list now, @ $1.50 each, are dated 1996, so they are getting a little long in the tooth: http://www.allelectronics.com/cgi-bin/item/LBAT-49/160/3.6V_LITHIUM_BATTERY,_AA_SIZE_W_SOLDER_TABS_.html
:Doug
::Doug,
::They're great for white LEDs too. Typically a forward voltage of 3.6vdc sets the current at about 20ma, which is a norm for most white LEDs. I keep a couple 3.6v nicad/nimh packs on my bench, along with a couple white LEDs on long flexible leads, for those really tight places incompatible with a regular flashlight.
::marv
::Marv, so you just strap the 3.6-V battery directly across the white LED? Without a ballast resistor? What's the forward voltage drop for a white LED?
::By the way, my previous source for those lithium batteries was All Electronics. But the ones they list now, @ $1.50 each, are dated 1996, so they are getting a little long in the tooth: http://www.allelectronics.com/cgi-bin/item/LBAT-49/160/3.6V_LITHIUM_BATTERY,_AA_SIZE_W_SOLDER_TABS_.html
::Doug
:::Doug,
:::They're great for white LEDs too. Typically a forward voltage of 3.6vdc sets the current at about 20ma, which is a norm for most white LEDs. I keep a couple 3.6v nicad/nimh packs on my bench, along with a couple white LEDs on long flexible leads, for those really tight places incompatible with a regular flashlight.
:::marv
