Regards
Steve
Hoo, boy, this is one big old radio. I need to peruse the schematics a while to get a feeling about this guy. I don't see, right off hand, hows the 6F6s could be causing this problem. I'll get back with you later, after I have studied the schematic a while.
Regards
Steve
Definitely check out the power transformer. Disconnect all three high voltage wires. Power up the transformer and carefully meter across two of them at a time. The two that give the highest reading are the two that should go to the rectifier plates. The remaining wire should give a reading half of what you saw with the other two wires when measured to either one of them (not both at the same time...don't do that or you'll fry the transformer). That remaining wire should be connected to B- according to the schematic. Also, the voltage between each of the other wires and this last remaining wire should be pretty much the same for both of the other wires. Significant difference may indicate transformer problems.
Agree with Thomas. That's the only way you can have that high of voltage. The other thing may be your meter? Either reading wrong or on AC rather than DC?
Don't operate a radio if voltage is that high. It's way above rating of electrolytic caps. They will get hot and explode with excessive voltage.
6F6's will get hot but plates & screen shouldn't be red.
:Did you do anything with the power transformer or rectifier wiring???? If you confused the three high voltage wires, you could easily have 700 volts instead of 350 at your rectifier cathode. Here's how: You're supposed to connect the two ends of the winding to the rectifier plates. The center tap goes to B-. However, if you connected one end to one plate, the center tap to the other plate, and the other end to B-, you'd get 700 volts. If you were to look at the cathode output from the rectifier on a scope, you'd see that every other wave was 700 volts and every other wave was 350 volts. When that passes through the filter system of your radio, it's a bit better than half wave rectification (350 volts is better than 0 volts), so it probably gets filtered quite well. The output should be something around 700 volts DC, and rather smooth. You may notice some excessive hum, but not too much.
:Definitely check out the power transformer. Disconnect all three high voltage wires. Power up the transformer and carefully meter across two of them at a time. The two that give the highest reading are the two that should go to the rectifier plates. The remaining wire should give a reading half of what you saw with the other two wires when measured to either one of them (not both at the same time...don't do that or you'll fry the transformer). That remaining wire should be connected to B- according to the schematic. Also, the voltage between each of the other wires and this last remaining wire should be pretty much the same for both of the other wires. Significant difference may indicate transformer problems.
:T.
Think I found it, the bleeder resistor R1B in parallel w/ C2 (16 mf cap) burned up. It's a big mother, 2520, 4W rating.
Heres hoping.
By the way, thanks for the transformer suggestion, it led me back to the resistor. I had to replace the 180 earlier on.
Regards
Steve
Regards and Happy New Year
Steve
Pins 4 or 6 may read close to or around 400 -420 vAC but that is if you reference it FROM the CT.
Across the whole winding (from pin 4 to pin 6) you will read 700vAV
But everything is referenced from the CT.
So you should also measure the DC voltage from the chassis or CT as a reference also.
Measuring DC referenced from the Chassis or CT you should measure about 370-400VDC at the input of the field coil and about 270-290vDC on the other side of the field coil.
