Eico tube tester model 666
9/23/2000 10:08:17 AMtesla
Hi
I have a Eico 666 tube tester, and have been looking for info, and perhaps someone else that has one to trade info with.
Regards,
Gene Lambert
9/23/2000 10:23:23 AMNorm Leal
Hi Tesla
What information are you looking for? The Eico 666 is a good tester for old tubes. It has a roll chart for settings.
Each lever controls a pin on the tube. Starting from the left the first lever is pin #1. Following is some information about these levers. There are 6 positions for each. The bottom ground, 2nd filament, 3rd low B+ for screen, 4th high B+ for plate, 5th grid #1 voltage adjusted by the control on the left and the top position open.
Set up the tester according to the chart and pull down the test lever on the right.
: Hi
: I have a Eico 666 tube tester, and have been looking for info, and perhaps someone else that has one to trade info with.
: Regards,
: Gene Lambert
