Philco mod. 50
12/24/2007 6:45:55 PMJon
Hello all,
I am starting on a Philco mod. 50 and have a question about cap # 15 on the schematic. It is a metal box with 5 leads. The schematic gives the values as a group(.1, .15, .25 2-.5's) but not as idividual values. The schematic shows all the # 15's but I can not find where the values are identified for the specific caps so I can trace them back and know what goes where. Thanks for any help.
Merry Christmas and a happy new year to all.
Jon.
12/24/2007 7:53:24 PMMark
:Hello all,
:I am starting on a Philco mod. 50 and have a question about cap # 15 on the schematic. It is a metal box with 5 leads. The schematic gives the values as a group(.1, .15, .25 2-.5's) but not as idividual values. The schematic shows all the # 15's but I can not find where the values are identified for the specific caps so I can trace them back and know what goes where. Thanks for any help.
:Merry Christmas and a happy new year to all.
:Jon.
You may try a couple of things: 1. Measure each value with a capacitance meter (remove the individual wire from its' connection) 2. Use .5 or 1 uf for all since bypass caps are usually non critical and see if it works normally. 3. contact the Philco repair bench linked to this site. 4. Have a great Christmas.
MRO
12/24/2007 8:48:58 PMNorm Leal
Hi Jon
Use this schematic:
http://www.philcoradio.com/tech/images/50.jpg
At the bottom capacitors are identified by numbers and wire color.
::Hello all,
::I am starting on a Philco mod. 50 and have a question about cap # 15 on the schematic. It is a metal box with 5 leads. The schematic gives the values as a group(.1, .15, .25 2-.5's) but not as idividual values. The schematic shows all the # 15's but I can not find where the values are identified for the specific caps so I can trace them back and know what goes where. Thanks for any help.
::Merry Christmas and a happy new year to all.
::Jon.
:You may try a couple of things: 1. Measure each value with a capacitance meter (remove the individual wire from its' connection) 2. Use .5 or 1 uf for all since bypass caps are usually non critical and see if it works normally. 3. contact the Philco repair bench linked to this site. 4. Have a great Christmas.
:MRO
12/24/2007 8:59:12 PMJon.
:Hi Jon
: Use this schematic:
:http://www.philcoradio.com/tech/images/50.jpg
: At the bottom capacitors are identified by numbers and wire color.
Norm,
Once again you are the MAN! Many thanks and Merry Christmas.
Jon.
:::Hello all,
:::I am starting on a Philco mod. 50 and have a question about cap # 15 on the schematic. It is a metal box with 5 leads. The schematic gives the values as a group(.1, .15, .25 2-.5's) but not as idividual values. The schematic shows all the # 15's but I can not find where the values are identified for the specific caps so I can trace them back and know what goes where. Thanks for any help.
:::Merry Christmas and a happy new year to all.
:::Jon.
::You may try a couple of things: 1. Measure each value with a capacitance meter (remove the individual wire from its' connection) 2. Use .5 or 1 uf for all since bypass caps are usually non critical and see if it works normally. 3. contact the Philco repair bench linked to this site. 4. Have a great Christmas.
::MRO
12/25/2007 9:33:34 AMTerry F
Jon,
Look closely at the picture Norm sent as it shows the value for the cap.
I rebuilt one on a Philco 71 recently and I marked each wire with the cap value. I cut the wires to the can and removed it, Pryed off the end cap very carefully to keep the tabs from breaking and removed the internals.
Then I mounted the new caps inside the can (using the schematci for the #15 can as shown at the bottom of the schemactic)and used various color wires to indicate value to match up with the originals. After re-assembly, the whole thing looked like it was new.
Terry F
12/25/2007 12:36:24 PMJon
:Jon,
:Look closely at the picture Norm sent as it shows the value for the cap.
:I rebuilt one on a Philco 71 recently and I marked each wire with the cap value. I cut the wires to the can and removed it, Pryed off the end cap very carefully to keep the tabs from breaking and removed the internals.
:Then I mounted the new caps inside the can (using the schematci for the #15 can as shown at the bottom of the schemactic)and used various color wires to indicate value to match up with the originals. After re-assembly, the whole thing looked like it was new.
:Terry F
Terry,
Thanks for the info. For some reason my schematics did not have the cap diagram. Once I got them, it was a snap to restuff the original can by just the method you describe. I just have to recone the speaker and it is done. I am surprised by the sound quality and volume from this TRF set even with a shot speaker cone.
Merry Christmas.
Jon.
