1946 Midland What is it??
12/23/2007 10:03:53 PMGeorge T
I made a mistake on the value of the blue resistors they are 100 ohms.
12/24/2007 11:49:04 AMNorm Leal
Hi
Should read 100 ohms on an ohm meter. If open the resistor is bad. A large resisror will be wire wound. Might need 100 ohms @ 10 watts?
:I made a mistake on the value of the blue resistors they are 100 ohms.
12/24/2007 1:43:56 PMGeorge T
:Hi
: Should read 100 ohms on an ohm meter. If open the resistor is bad. A large resisror will be wire wound. Might need 100 ohms @ 10 watts?
::I made a mistake on the value of the blue resistors they are 100 ohms.
Thank You for the information, George.
