RE: Hoffman Model #637
12/23/2007 9:23:56 AMvolts
Hi
I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
Volts
12/23/2007 12:14:32 PMNorm Leal
Hi
Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
: Hi
: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
:Volts
12/23/2007 1:03:35 PMvolts
:Hi
: Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
:Hi Norm
Ok, thanks for the info:)
Volts
:: Hi
:: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
::Volts
1/1/2008 10:45:21 AMvolts
:Hi
:Hi Norm
As I wait to get the schematic, could you tell me about what year this TV was made?
Volts
:: Hi
::Volts
1/1/2008 12:04:26 PMNorm Leal
Hi
Sam's #141 covers TV's made in 1951.
::Hi
:: Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
::Hi Norm
: As I wait to get the schematic, could you tell me about what year this TV was made?
:Volts
::: Hi
::: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
:::Volts
1/1/2008 12:12:15 PMvolts
:Hi
: Sam's #141 covers TV's made in 1951.
:Hi Norm
Thanks! I was kind of figuring 50 or 51, but was not sure, thanks for the info:)
Volts
:::Hi
::: Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
:::Hi Norm
:: As I wait to get the schematic, could you tell me about what year this TV was made?
::Volts
:::: Hi
:::: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
::::Volts
1/1/2008 12:13:58 PMvolts
::Hi
:: Sam's #141 covers TV's made in 1951.
::Hi Norm
: Thanks! I was kind of figuring 50 or 51, but was not sure, thanks for the info:)
:Volts
Wonder what this TV would be worth if it was in working order?
Volts
::::Hi
:::: Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
::::Norm
::::Hi Norm
::: As I wait to get the schematic, could you tell me about what year this TV was made?
:::Volts
::::: Hi
::::: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
:::::Volts
1/1/2008 12:49:54 PMNorm Leal
Hi
Don't expect much, maybe $50. There aren't a lot of collectors for TV. If projection or something unusual it would bring in more.
Does your TV still have the colored front glass? When people saw what a nice picture these TVs had, without the glass, they would ask for it to be left off. If you have the yellow glass it might be worth more?
:::Hi
::: Sam's #141 covers TV's made in 1951.
:::Hi Norm
:: Thanks! I was kind of figuring 50 or 51, but was not sure, thanks for the info:)
::Volts
:Wonder what this TV would be worth if it was in working order?
:Volts
:::::Hi
::::: Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
:::::Norm
:::::Hi Norm
:::: As I wait to get the schematic, could you tell me about what year this TV was made?
::::Volts
:::::: Hi
:::::: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
::::::Volts
1/1/2008 1:48:40 PMvolts
:Hi
: Don't expect much, maybe $50. There aren't a lot of collectors for TV. If projection or something unusual it would bring in more.
: Does your TV still have the colored front glass? When people saw what a nice picture these TVs had, without the glass, they would ask for it to be left off. If you have the yellow glass it might be worth more?
:Hi Norm
Yes it still has the colored glass in it with the gold rim around it, it is all original, nothing has been taken off.
Volts
::::Hi
:::: Sam's #141 covers TV's made in 1951.
::::Norm
::::Hi Norm
::: Thanks! I was kind of figuring 50 or 51, but was not sure, thanks for the info:)
:::Volts
::Wonder what this TV would be worth if it was in working order?
::Volts
::::::Hi
:::::: Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
::::::Norm
::::::Hi Norm
::::: As I wait to get the schematic, could you tell me about what year this TV was made?
:::::Volts
::::::: Hi
::::::: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
:::::::Volts
1/1/2008 1:51:41 PMvolts
::Hi
:: Don't expect much, maybe $50. There aren't a lot of collectors for TV. If projection or something unusual it would bring in more.
:: Does your TV still have the colored front glass? When people saw what a nice picture these TVs had, without the glass, they would ask for it to be left off. If you have the yellow glass it might be worth more?
::Hi Norm
: Yes it still has the colored glass in it with the gold rim around it, it is all original, nothing has been taken off, and the glass is in perfect condition! not a scratch on it!
:Volts
:::::Hi
::::: Sam's #141 covers TV's made in 1951.
:::::Norm
:::::Hi Norm
:::: Thanks! I was kind of figuring 50 or 51, but was not sure, thanks for the info:)
::::Volts
:::Wonder what this TV would be worth if it was in working order?
:::Volts
:::::::Hi
::::::: Information on Hoffman Model 637 is in Sam's Photofact #141-7. You can usually get this from a local library. Sam's also sells the information by calling 800-428-7267.
:::::::Norm
:::::::Hi Norm
:::::: As I wait to get the schematic, could you tell me about what year this TV was made?
::::::Volts
:::::::: Hi
:::::::: I have an old Hoffman B&W Television Set I'm working on and I'm in need of a schematic for this set, in particular the High Voltage Rectifier Section, the Model Number is #637 and CHassis #183. does anyone have this, or know of where I can get one?
::::::::Volts
