Connecting 4 ohm speaker to 8 ohm speaker output
9/13/2000 11:04:29 AMSven Weil
I'm replacing a speaker in a radio that originally used an 8 ohm speaker. The replacement is a 4 ohm speaker (it was the only one I could find in that size). Do I need to put a resistor in series with the speaker in order to crank it up to 8 ohms or higher? I've read that you should never connect low impedance speakers to high impedance amps without some sort of resistor in series.
9/13/2000 11:14:36 AMNorm Leal
Hi Sven
Others may disagree but I suggest connecting the 4 ohm speaker directly without a resistor. The mismatch will reduce available power from the amp but won't effect normal listening..
Never operate an amp without a load. Always have a speaker or resistor on the output. Without a load there will be peak voltages which can destroy output transistors and caps.
In old radios low impedance would be considered 4-8 ohms, high 2000-5000 ohms. Here it will make a difference and requires a matching transformer.
: I'm replacing a speaker in a radio that originally used an 8 ohm speaker. The replacement is a 4 ohm speaker (it was the only one I could find in that size). Do I need to put a resistor in series with the speaker in order to crank it up to 8 ohms or higher? I've read that you should never connect low impedance speakers to high impedance amps without some sort of resistor in series.
9/13/2000 3:58:52 PMScot
: Hi Sven
: Others may disagree but I suggest connecting the 4 ohm speaker directly without a resistor. The mismatch will reduce available power from the amp but won't effect normal listening..
: Never operate an amp without a load. Always have a speaker or resistor on the output. Without a load there will be peak voltages which can destroy output transistors and caps.
: In old radios low impedance would be considered 4-8 ohms, high 2000-5000 ohms. Here it will make a difference and requires a matching transformer.
: Norm
: : I'm replacing a speaker in a radio that originally used an 8 ohm speaker. The replacement is a 4 ohm speaker (it was the only one I could find in that size). Do I need to put a resistor in series with the speaker in order to crank it up to 8 ohms or higher? I've read that you should never connect low impedance speakers to high impedance amps without some sort of resistor in series.
3/16/2002 9:54:10 AMphilip hyde
: : Hi Sven
: : Others may disagree but I suggest connecting the 4 ohm speaker directly without a resistor. The mismatch will reduce available power from the amp but won't effect normal listening..
: : Never operate an amp without a load. Always have a speaker or resistor on the output. Without a load there will be peak voltages which can destroy output transistors and caps.
: : In old radios low impedance would be considered 4-8 ohms, high 2000-5000 ohms. Here it will make a difference and requires a matching transformer.
: : Norm
: : : I'm replacing a speaker in a radio that originally used an 8 ohm speaker. The replacement is a 4 ohm speaker (it was the only one I could find in that size). Do I need to put a resistor in series with the speaker in order to crank it up to 8 ohms or higher? I've read that you should never connect low impedance speakers to high impedance amps without some sort of resistor in series.
9/13/2000 4:05:49 PMScot
Norm,
As a related subject. I have a regen up and running. It uses a single dual triode (6SL7). Powersupply is the AES kit with extra caps to reduce AC hum. I usually listen using an amplified pair of computer speakers. It doesn't sound very good. The RS amplified speaker is worse. The set won't drive a modern speaker. I am sure the impedence is way off. Should I get an audio output transformer?? If so what kind?? Would another stage of amplification be in order??
: Hi Sven
: Norm
2/13/2001 10:00:06 AMAllan
: Hi Sven
: Norm
if we need to add an resistor what should it be. If i don't will I just not get the volume from my speakers that I normally would?
2/13/2001 10:00:49 AMAllan
: Hi Sven
: Norm
2/14/2001 10:37:36 AMallan
: Hi Sven
: Norm
2/14/2001 10:41:56 AMallan
: : Hi should i add a resistor to my speakers to bring them up to a 8 ohm. if so what type of resistor should i use. without the resistor will the only dirrerence be that i won't be able to get the same volume out of my amp?
2/14/2001 10:43:43 AMallan
: : : Hi should i add a resistor to my speakers from 4 ohm to a 8 ohm. if so what type of resistor should i use. without the resistor will the only difference be that i won't be able to get the same volume out of my amp?
3/9/2001 3:01:08 PMmike
you should buy a aiwa av-d50 and get rid of your problems
6/2/2001 2:25:43 AMJuan
I need schematic for RCA 757MX 6 TUBES
6/2/2001 2:33:01 AMJUAN
: I need schematic for RCA 757MX 6 TUBES
THANKS
