That cap is probably the cathode bypass cap. There is probably a 150-220 Ohm resistor from cathode pin 8 to B minus with this cap across it.
:I have an unidentified Canadian Marconi which I’m trying to get working. I’m recapping but can’t identify one of the capacitors. It’s positive end is connected to pin 8 of 50L6, then through a .005uf capacitor to pin 3 of 50L6. The negative is connected to the phono switch and from there to the negative terminal of the on/off switch. This capacitor looks like a regular, paper wrapped capacitor and it looks like "25 mfd at 25 VWDC" is written on the wrapping...Is this realistic, or am I reading it wrong??
:Sorry, I can’t help with a schematic but it's a six tube radio with the tube line-up as follows; 35W4, 50L6, 12BA6, 12AV6, 12BA6, 12BE6.
:Regards
:Job
:Job,
:That cap is probably the cathode bypass cap. There is probably a 150-220 Ohm resistor from cathode pin 8 to B minus with this cap across it.
:Radiodoc
::I have an unidentified Canadian Marconi which I’m trying to get working. I’m recapping but can’t identify one of the capacitors. It’s positive end is connected to pin 8 of 50L6, then through a .005uf capacitor to pin 3 of 50L6. The negative is connected to the phono switch and from there to the negative terminal of the on/off switch. This capacitor looks like a regular, paper wrapped capacitor and it looks like "25 mfd at 25 VWDC" is written on the wrapping...Is this realistic, or am I reading it wrong??
::Sorry, I can’t help with a schematic but it's a six tube radio with the tube line-up as follows; 35W4, 50L6, 12BA6, 12AV6, 12BA6, 12BE6.
::Regards
::Job
Yes. The plus on the cap goes to the cathode pin 8 on the socket and the minus goes to B minus. Be careful of polarity with all electrolytics (non-polarized caps an exception). The metal tube (covered with plastic/vinyl) is the minus and the end with the plastic/rubber insulator with the wire feeding thru is the positive. There are some radios that use multi-sectioned power supply caps that also contain the output tube cathode bypass cap in the multi-section cap can or paper tube.
:Doc, is that capacitor supposed to be electrolytic or am I reading it wrong?? It looks like 25 mfd but difficult to say for sure.
:Regards
::Job,
::That cap is probably the cathode bypass cap. There is probably a 150-220 Ohm resistor from cathode pin 8 to B minus with this cap across it.
::Radiodoc
:::I have an unidentified Canadian Marconi which I’m trying to get working. I’m recapping but can’t identify one of the capacitors. It’s positive end is connected to pin 8 of 50L6, then through a .005uf capacitor to pin 3 of 50L6. The negative is connected to the phono switch and from there to the negative terminal of the on/off switch. This capacitor looks like a regular, paper wrapped capacitor and it looks like "25 mfd at 25 VWDC" is written on the wrapping...Is this realistic, or am I reading it wrong??
:::Sorry, I can’t help with a schematic but it's a six tube radio with the tube line-up as follows; 35W4, 50L6, 12BA6, 12AV6, 12BA6, 12BE6.
:::Regards
:::Job
:Job,
:Yes. The plus on the cap goes to the cathode pin 8 on the socket and the minus goes to B minus. Be careful of polarity with all electrolytics (non-polarized caps an exception). The metal tube (covered with plastic/vinyl) is the minus and the end with the plastic/rubber insulator with the wire feeding thru is the positive. There are some radios that use multi-sectioned power supply caps that also contain the output tube cathode bypass cap in the multi-section cap can or paper tube.
:Radiodoc
::Doc, is that capacitor supposed to be electrolytic or am I reading it wrong?? It looks like 25 mfd but difficult to say for sure.
::Regards
:::Job,
:::That cap is probably the cathode bypass cap. There is probably a 150-220 Ohm resistor from cathode pin 8 to B minus with this cap across it.
:::Radiodoc
::::I have an unidentified Canadian Marconi which I’m trying to get working. I’m recapping but can’t identify one of the capacitors. It’s positive end is connected to pin 8 of 50L6, then through a .005uf capacitor to pin 3 of 50L6. The negative is connected to the phono switch and from there to the negative terminal of the on/off switch. This capacitor looks like a regular, paper wrapped capacitor and it looks like "25 mfd at 25 VWDC" is written on the wrapping...Is this realistic, or am I reading it wrong??
::::Sorry, I can’t help with a schematic but it's a six tube radio with the tube line-up as follows; 35W4, 50L6, 12BA6, 12AV6, 12BA6, 12BE6.
::::Regards
::::Job
