Stromberg-Carlson 400H replacement Pwr transformer
11/23/2007 12:01:29 PMDave Froehlich
Hello All,
I have another egg fryer power transformer, this time, in a Stromberg-Carlson 400H. I usually ask everyone's opinion before I make my final selection. There is a power transformer that has a B+ winding of: 280-0-280 at 60mA. I'm not sure that's enough but it cost the least. What's your opinion? Which Hammond Power transformer would you use in the Stromberg Carlson 400H?
dave2@dreamscape.com I may be leaving borg soon, so I'll start using one of my other e-mail addresses soon.
11/23/2007 12:44:42 PMEdd
Looks like that set is merely using an 80 rectifier and four other 6V tubes. Also with it only using a single ended 6V6, that voltage should be sufficient and be
less strain, particularly if it ends up getting a lots of use.
The original transformer core mass seems to be somewhat in that order:
:Hello All,
: I have another egg fryer power transformer, this time, in a Stromberg-Carlson 400H. I usually ask everyone's opinion before I make my final selection. There is a power transformer that has a B+ winding of: 280-0-280 at 60mA. I'm not sure that's enough but it cost the least. What's your opinion? Which Hammond Power transformer would you use in the Stromberg Carlson 400H?
:Thanks,
:Dave
:dave2@dreamscape.com I may be leaving borg soon, so I'll start using one of my other e-mail addresses soon.
11/24/2007 1:37:05 AMDave Froehlich
Edd,
The speaker in the Radio I have here has a speaker with a field coil. If that doesn't make any difference, then I'll go for the low priced transformer.
Thanks Very Much,
:Looks like that set is merely using an 80 rectifier and four other 6V tubes. Also with it only using a single ended 6V6, that voltage should be sufficient and be
:less strain, particularly if it ends up getting a lots of use.
:The original transformer core mass seems to be somewhat in that order:
::Hello All,
:: I have another egg fryer power transformer, this time, in a Stromberg-Carlson 400H. I usually ask everyone's opinion before I make my final selection. There is a power transformer that has a B+ winding of: 280-0-280 at 60mA. I'm not sure that's enough but it cost the least. What's your opinion? Which Hammond Power transformer would you use in the Stromberg Carlson 400H?
::Thanks,
::Dave
::dave2@dreamscape.com I may be leaving borg soon, so I'll start using one of my other e-mail addresses soon.
11/24/2007 1:38:41 AMDave Froehlich
Edd,
I meant to say that the speaker has a field coil in this radio. But somehow speaker got in there twice.
Thanks Again,
:Edd,
:The speaker in the Radio I have here has a speaker with a field coil. If that doesn't make any difference, then I'll go for the low priced transformer.
:Thanks Very Much,
:Dave
::Looks like that set is merely using an 80 rectifier and four other 6V tubes. Also with it only using a single ended 6V6, that voltage should be sufficient and be
::less strain, particularly if it ends up getting a lots of use.
::The original transformer core mass seems to be somewhat in that order:
::73's de Edd
:::Hello All,
::: I have another egg fryer power transformer, this time, in a Stromberg-Carlson 400H. I usually ask everyone's opinion before I make my final selection. There is a power transformer that has a B+ winding of: 280-0-280 at 60mA. I'm not sure that's enough but it cost the least. What's your opinion? Which Hammond Power transformer would you use in the Stromberg Carlson 400H?
:::Thanks,
:::Dave
:::dave2@dreamscape.com I may be leaving borg soon, so I'll start using one of my other e-mail addresses soon.
12/10/2007 11:30:29 PMDave Froehlich
Edd,
That new power transformer works perfectly.
::Hello All,
::Thanks,
::Dave
