http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140176843829
Looking at the third photograph from the bottom, one can just see this large transformer on the left, behind the two tubes. It is stamped: 3752-D. Just next to it on the right is a large square can, soldered to the chassis, which I presume is filled with filter caps. The chassis appears to be nickel plated. The tube lineup is as follows, as viewed from left to right in the third last photo:
Marked: 280 245 245 227 224 224 224 224
Installed: 80 45 - 56 24A 24A 24A 24A
Any help is most sincerely appreciated!
:Hi! I recently acquired a Monarch radio from the late 1920's or early 1930's, but am having trouble identifying it and must defer to the knowledgeable people on this excellent site. I hope to get a schematic so I can restore it. Unfortunately, there are no identifying marks on it that I can see, save for one number stamped on a large transformer. Please follow this link to see photographs of it:
:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140176843829
:Looking at the third photograph from the bottom, one can just see this large transformer on the left, behind the two tubes. It is stamped: 3752-D. Just next to it on the right is a large square can, soldered to the chassis, which I presume is filled with filter caps. The chassis appears to be nickel plated. The tube lineup is as follows, as viewed from left to right in the third last photo:
:Marked: 280 245 245 227 224 224 224 224
:Installed: 80 45 - 56 24A 24A 24A 24A
:Any help is most sincerely appreciated!
::Hi! I recently acquired a Monarch radio from the late 1920's or early 1930's, but am having trouble identifying it and must defer to the knowledgeable people on this excellent site. I hope to get a schematic so I can restore it. Unfortunately, there are no identifying marks on it that I can see, save for one number stamped on a large transformer. Please follow this link to see photographs of it:
::http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140176843829
::Looking at the third photograph from the bottom, one can just see this large transformer on the left, behind the two tubes. It is stamped: 3752-D. Just next to it on the right is a large square can, soldered to the chassis, which I presume is filled with filter caps. The chassis appears to be nickel plated. The tube lineup is as follows, as viewed from left to right in the third last photo:
::Marked: 280 245 245 227 224 224 224 224
::Installed: 80 45 - 56 24A 24A 24A 24A
::Any help is most sincerely appreciated!
:Many radios of the nineteen thirties were made by the detrola radio corp of detroit Michigan the D in the model # may reflect that it was made by detrola or DRC corp Detrola was the largest manufacturer of radios in the USA in 1937
:Scott McLeskey
:detrolakid@aol.com
:::Hi! I recently acquired a Monarch radio from the late 1920's or early 1930's, but am having trouble identifying it and must defer to the knowledgeable people on this excellent site. I hope to get a schematic so I can restore it. Unfortunately, there are no identifying marks on it that I can see, save for one number stamped on a large transformer. Please follow this link to see photographs of it:
:::http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140176843829
:::Looking at the third photograph from the bottom, one can just see this large transformer on the left, behind the two tubes. It is stamped: 3752-D. Just next to it on the right is a large square can, soldered to the chassis, which I presume is filled with filter caps. The chassis appears to be nickel plated. The tube lineup is as follows, as viewed from left to right in the third last photo:
:::Marked: 280 245 245 227 224 224 224 224
:::Installed: 80 45 - 56 24A 24A 24A 24A
:::Any help is most sincerely appreciated!
If you "Google" Monarch Radio, you will find several references that may be of help. There are three companies I found that could be involved. Steinite, Warwick, and King Manufacturing Corp. Check out King's Model 101 Monarch schematic. It might get you at least in the ballpark.
Good luck
Bill B.
::Many radios of the nineteen thirties were made by the detrola radio corp of detroit Michigan the D in the model # may reflect that it was made by detrola or DRC corp Detrola was the largest manufacturer of radios in the USA in 1937
::Scott McLeskey
::detrolakid@aol.com
::::Hi! I recently acquired a Monarch radio from the late 1920's or early 1930's, but am having trouble identifying it and must defer to the knowledgeable people on this excellent site. I hope to get a schematic so I can restore it. Unfortunately, there are no identifying marks on it that I can see, save for one number stamped on a large transformer. Please follow this link to see photographs of it:
::::http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140176843829
::::Looking at the third photograph from the bottom, one can just see this large transformer on the left, behind the two tubes. It is stamped: 3752-D. Just next to it on the right is a large square can, soldered to the chassis, which I presume is filled with filter caps. The chassis appears to be nickel plated. The tube lineup is as follows, as viewed from left to right in the third last photo:
::::Marked: 280 245 245 227 224 224 224 224
::::Installed: 80 45 - 56 24A 24A 24A 24A
::::Any help is most sincerely appreciated!
