Air Castle mystery model
11/19/2007 6:09:49 PMTex
Does anyone know the model number of this AirCastle? It has 6 tubes, two #30, 32, 33, 34, & 1C6. The serial # is 107445.
11/19/2007 8:03:52 PMJon
:Does anyone know the model number of this AirCastle? It has 6 tubes, two #30, 32, 33, 34, & 1C6. The serial # is 107445.
Tex,
Try comparing your radio to chassis schematic L7 or Z5 in the resources section under Aircastle. It was common for the same chassis to be placed in many different cabinet styles back then.
Jon.
Aircastle in the resources
11/19/2007 8:05:26 PMjon
::Does anyone know the model number of this AirCastle? It has 6 tubes, two #30, 32, 33, 34, & 1C6. The serial # is 107445.
:Tex,
:Try comparing your radio to chassis schematic L7 or Z5 in the resources section under Aircastle. It was common for the same chassis to be placed in many different cabinet styles back then.
:Jon.
: Aircastle in the resources
Tex,
Your radio is similar to the model L6-yours might be the battery model of that series.
Jon.
11/20/2007 8:28:41 AMTex
:::Does anyone know the model number of this AirCastle? It has 6 tubes, two #30, 32, 33, 34, & 1C6. The serial # is 107445.
::Tex,
::Try comparing your radio to chassis schematic L7 or Z5 in the resources section under Aircastle. It was common for the same chassis to be placed in many different cabinet styles back then.
::Jon.
:: Aircastle in the resources
:Tex,
:Your radio is similar to the model L6-yours might be the battery model of that series.
:Jon.
The chassis in this radio is just like the one that says "6 tube batt. super" except where that chassis has a #19 mine has a 30 & where the schematic has the 30 that is next to the 19, mine has a 30 there. The tube numbers are stamped on the sockets.
