Speaker coil resistence
11/14/2007 9:19:54 PMDan Livesay
Hello
I need to find the resistence of the 6 inch speaker # 2 part #49-158 for a Zenith model 12 U 159.Riders gives the resistence of the 12 inch field coil but not the 6 inch.Thanks for any help you can give.
11/14/2007 10:56:40 PMWatson Blount
Dan: The #1 speaker field is given as 1400 ohm. There is a note on the schematic that states "#2 speaker field is automatically substituted for 4955 ohm section of candohm resistor when speaker plug is insrted in set" - I'd assume the #2 speaker field would approximate the substituted value of the resistor and be around 5000 ohms. Watson
____________
:Hello
: I need to find the resistence of the 6 inch speaker # 2 part #49-158 for a Zenith model 12 U 159.Riders gives the resistence of the 12 inch field coil but not the 6 inch.Thanks for any help you can give.
