Philco 46-1201 code 127
11/4/2007 7:24:23 PMBill B.
I re-capped this neat phono-radio, resulting with the phono working fine, but when I switch to the radio side, I can tune stations, but have distorted reception with a background buzzing. Alignment is not the problem. I was very careful, and am sure I installed the power caps with the same polarity as what I replaced. My problem is that I cannot find a code 127 diagram. I need to be verify the resistors. It seems that Philco had several different circuits involved in a production run. The power circuit is strange in that I have a 16mfg cap that has a neg connection to the same post that has a pos connections from another 16mfg cap. I will appreciate any advice.
Bill B.
11/4/2007 7:54:58 PMRadiodoc
Bill B.,
Doess your radio/phonograph use a series filament circuit? If so does it use a 50X6 rectifier tube in the power supply (or another tube that has two diodes in it). If it does, the circuit may be what is called a voltage doubler circuit. You might check out a 46-1203 and see if your power supply circuit is similar to that one.
:I re-capped this neat phono-radio, resulting with the phono working fine, but when I switch to the radio side, I can tune stations, but have distorted reception with a background buzzing. Alignment is not the problem. I was very careful, and am sure I installed the power caps with the same polarity as what I replaced. My problem is that I cannot find a code 127 diagram. I need to be verify the resistors. It seems that Philco had several different circuits involved in a production run. The power circuit is strange in that I have a 16mfg cap that has a neg connection to the same post that has a pos connections from another 16mfg cap. I will appreciate any advice.
:Thanks,
:Bill B.
11/5/2007 9:12:46 AMBill B.
Yes, it has a series circuit with a 50Y6 rectifier. I'll check out the 46-1203.
Bill
:Bill B.,
:Doess your radio/phonograph use a series filament circuit? If so does it use a 50X6 rectifier tube in the power supply (or another tube that has two diodes in it). If it does, the circuit may be what is called a voltage doubler circuit. You might check out a 46-1203 and see if your power supply circuit is similar to that one.
:Radiodoc
::I re-capped this neat phono-radio, resulting with the phono working fine, but when I switch to the radio side, I can tune stations, but have distorted reception with a background buzzing. Alignment is not the problem. I was very careful, and am sure I installed the power caps with the same polarity as what I replaced. My problem is that I cannot find a code 127 diagram. I need to be verify the resistors. It seems that Philco had several different circuits involved in a production run. The power circuit is strange in that I have a 16mfg cap that has a neg connection to the same post that has a pos connections from another 16mfg cap. I will appreciate any advice.
::Thanks,
::Bill B.
11/5/2007 9:32:47 AMRobert Blakeley
:Yes, it has a series circuit with a 50Y6 rectifier. I'll check out the 46-1203.
:Thanks,
:Bill
::Bill B.,
::Doess your radio/phonograph use a series filament circuit? If so does it use a 50X6 rectifier tube in the power supply (or another tube that has two diodes in it). If it does, the circuit may be what is called a voltage doubler circuit. You might check out a 46-1203 and see if your power supply circuit is similar to that one.
::Radiodoc
:::I re-capped this neat phono-radio, resulting with the phono working fine, but when I switch to the radio side, I can tune stations, but have distorted reception with a background buzzing. Alignment is not the problem. I was very careful, and am sure I installed the power caps with the same polarity as what I replaced. My problem is that I cannot find a code 127 diagram. I need to be verify the resistors. It seems that Philco had several different circuits involved in a production run. The power circuit is strange in that I have a 16mfg cap that has a neg connection to the same post that has a pos connections from another 16mfg cap. I will appreciate any advice.
:::Thanks,
:::Bill B.
Recheck the electrolytic wiring. From your description, it sounds as though you have followed someone elses previous incorrect connections. The schematic does not indicate that such a connection should exist
11/5/2007 10:21:14 AMRadiodoc
::Yes, it has a series circuit with a 50Y6 rectifier. I'll check out the 46-1203.
::Thanks,
::Bill
:::Bill B.,
:::Doess your radio/phonograph use a series filament circuit? If so does it use a 50X6 rectifier tube in the power supply (or another tube that has two diodes in it). If it does, the circuit may be what is called a voltage doubler circuit. You might check out a 46-1203 and see if your power supply circuit is similar to that one.
:::Radiodoc
::::I re-capped this neat phono-radio, resulting with the phono working fine, but when I switch to the radio side, I can tune stations, but have distorted reception with a background buzzing. Alignment is not the problem. I was very careful, and am sure I installed the power caps with the same polarity as what I replaced. My problem is that I cannot find a code 127 diagram. I need to be verify the resistors. It seems that Philco had several different circuits involved in a production run. The power circuit is strange in that I have a 16mfg cap that has a neg connection to the same post that has a pos connections from another 16mfg cap. I will appreciate any advice.
::::Thanks,
::::Bill B.
:Recheck the electrolytic wiring. From your description, it sounds as though you have followed someone elses previous incorrect connections. The schematic does not indicate that such a connection should exist
Robert,
If the radio uses a full-wave voltage doubler (50Y6 contains two diode sections) then two caps will be stacked (connected in series so to speak) with a plus and minus connected together and one side of the AC line connected at the junction of the two. The plus of one cap of the combination goes to a cathode and the minus of the other cap goes to a plate of the 50Y5. The other plate and cathode are tied together and goes to the other AC line.
11/4/2007 8:47:39 PMZ-
If the phono works fine (audio section I understand?) then it seems your radio suffers of tunable hum.
Check your rectifier as it was suggested in the previous reply. Or try bypassing the rectifier plate to ground using a .001uF. Also sometimes, a line bypass cap is necessary (they are usually around .05uF) and go from one side of the line to the chassis. Sometimes even two are used to create a fake isolated chassis on AC/DC sets.
Use Google (in "groups") and search for the terms "tunable hum". Sometimes a tube can be bad, but most of the time it is related to the power supply section.
11/4/2007 9:20:53 PMRadiodoc
:If the phono works fine (audio section I understand?) then it seems your radio suffers of tunable hum.
:Check your rectifier as it was suggested in the previous reply. Or try bypassing the rectifier plate to ground using a .001uF. Also sometimes, a line bypass cap is necessary (they are usually around .05uF) and go from one side of the line to the chassis. Sometimes even two are used to create a fake isolated chassis on AC/DC sets.
:Use Google (in "groups") and search for the terms "tunable hum". Sometimes a tube can be bad, but most of the time it is related to the power supply section.
Bill B.,
It is possible there is something that may be causing the buzzing from external to the radio such as fluorescent lights, light dimmers, computers, DVD players, battery chargers, wifi/wireless devices, TVs and etc. There are many devices today that can interfere with AM reception.
11/4/2007 10:12:11 PMZ-
:It is possible there is something that may be causing the buzzing from external to the radio such as fluorescent lights, light dimmers, computers, DVD players, battery chargers, wifi/wireless devices, TVs and etc. There are many devices today that can interfere with AM reception.
:Radiodoc
Good point.
But I presumed (wrongly ?) the OP has already checked that issue with another radio ? i.e. only that particular radio has that distortion and hum problem ?
11/5/2007 9:17:25 AMBill B.
Yes, I do have a fluorescent above my workbench, I get a hum on some radios, but it will be easy enough to see if that creates the distortion that I don't have on the other radios.
Thanks guys.
Bill B.
::It is possible there is something that may be causing the buzzing from external to the radio such as fluorescent lights, light dimmers, computers, DVD players, battery chargers, wifi/wireless devices, TVs and etc. There are many devices today that can interfere with AM reception.
::Radiodoc
:Good point.
:But I presumed (wrongly ?) the OP has already checked that issue with another radio ? i.e. only that particular radio has that distortion and hum problem ?
11/5/2007 9:25:07 AMWatson Blount
Bill: I had a set do that a few years ago and I nearly went buggie trying to find it. Check the connections to the antenna loop very carefully to make sure it is hooked up correctly with no broken wires or cold solder joints. That's was my fix - hope it is yours too. Watson
____________________________
:Yes, I do have a fluorescent above my workbench, I get a hum on some radios, but it will be easy enough to see if that creates the distortion that I don't have on the other radios.
:Thanks guys.
:Bill B.
:::It is possible there is something that may be causing the buzzing from external to the radio such as fluorescent lights, light dimmers, computers, DVD players, battery chargers, wifi/wireless devices, TVs and etc. There are many devices today that can interfere with AM reception.
:::Radiodoc
::Good point.
::But I presumed (wrongly ?) the OP has already checked that issue with another radio ? i.e. only that particular radio has that distortion and hum problem ?
11/5/2007 1:12:47 PMBill B.
:Bill: I had a set do that a few years ago and I nearly went buggie trying to find it. Check the connections to the antenna loop very carefully to make sure it is hooked up correctly with no broken wires or cold solder joints. That's was my fix - hope it is yours too. Watson
I'll check it. I'm nearly "buggie" about this myself. HA!
:____________________________
::Yes, I do have a fluorescent above my workbench, I get a hum on some radios, but it will be easy enough to see if that creates the distortion that I don't have on the other radios.
::Thanks guys.
::Bill B.
::::It is possible there is something that may be causing the buzzing from external to the radio such as fluorescent lights, light dimmers, computers, DVD players, battery chargers, wifi/wireless devices, TVs and etc. There are many devices today that can interfere with AM reception.
::::Radiodoc
:::Good point.
:::But I presumed (wrongly ?) the OP has already checked that issue with another radio ? i.e. only that particular radio has that distortion and hum problem ?
11/5/2007 10:55:04 AMRadiodoc
Bill B.,
If you would like, I could email you a couple of jpgs of a couple of pages that show a full-wave rectifier circuit with a bit of explanation of how it works. The jpegs are about 130KB each. Let me know.
:Thanks,
:Bill B.
11/5/2007 10:58:02 AMRadiodoc
:Bill B.,
:If you would like, I could email you a couple of jpgs of a couple of pages that show a full-wave rectifier circuit with a bit of explanation of how it works. The jpegs are about 130KB each. Let me know.
:Radiodoc
Bill B.,
I should have said full-wave voltage doubler rectifier circuit.
::Thanks,
::Bill B.
11/5/2007 1:13:54 PMBill B.
::Bill B.,
::If you would like, I could email you a couple of jpgs of a couple of pages that show a full-wave rectifier circuit with a bit of explanation of how it works. The jpegs are about 130KB each. Let me know.
::Radiodoc
:Bill B.,
:I should have said full-wave voltage doubler rectifier circuit.
:Radiodoc
Yes, I would appreciate that info.
:::Thanks,
:::Bill B.
11/5/2007 2:09:24 PMRadiodoc
Bill B.,
The jpgs have been sent.
:::Bill B.,
:::If you would like, I could email you a couple of jpgs of a couple of pages that show a full-wave rectifier circuit with a bit of explanation of how it works. The jpegs are about 130KB each. Let me know.
:::Radiodoc
::Bill B.,
::I should have said full-wave voltage doubler rectifier circuit.
::Radiodoc
:Yes, I would appreciate that info.
::::Thanks,
::::Bill B.
11/6/2007 12:57:44 PMBill B.
:Bill B.,
:The jpgs have been sent.
:Radiodoc
Got them! Thanks! This explains the (-) from one 16mfg cap connected to the same post as the (+)from another 16mfg cap. Also I have noticed that when the antenna is not connected, the radio has NO background buzz, even with my workbench flourescent lights on. Another item of pondering is that when the tuner is run up from 550, the volume goes up.
Bill B.
::::Bill B.,
::::If you would like, I could email you a couple of jpgs of a couple of pages that show a full-wave rectifier circuit with a bit of explanation of how it works. The jpegs are about 130KB each. Let me know.
::::Radiodoc
:::Bill B.,
:::I should have said full-wave voltage doubler rectifier circuit.
:::Radiodoc
::Yes, I would appreciate that info.
:::::I re-capped this neat phono-radio, resulting with the phono working fine, but when I switch to the radio side, I can tune stations, but have distorted reception with a background buzzing. Alignment is not the problem. I was very careful, and am sure I installed the power caps with the same polarity as what I replaced. My problem is that I cannot find a code 127 diagram. I need to be verify the resistors. It seems that Philco had several different circuits involved in a production run. The power circuit is strange in that I have a 16mfg cap that has a neg connection to the same post that has a pos connections from another 16mfg cap. I will appreciate any advice.
:::::Thanks,
:::::Bill B.
