Does your tube tester have #26 listed? An 01A is about the same as a 26 but has a 5 volt filament. Set up the tester for 26 and increase filament voltage to 5. 201A, 301A tests the same as 01A. Tubes with prefix UX201A are globe shaped tubes with RCA name.
:My hickok 600a does not have this tube listed.does anybody know what settings I would use? thank you. 201a 301a etc.
Rejuvenation seems to work better in globe type O-1A's rather than ST's - I guess filament composition changed over the years. There were some factory-built rejuvenators that I've occasionally seen at swap meets (and I have a set of plans for a new construction) - but you can use your tube tester justb as well. Know that you will burn out a few filaments for every tube you save - so use this procedure for tubes you are willing to sacrifice to the 'dud' box. But even then, you can transistorize the dud for a few bucks (details available if interested)...
