Filament xfrmr replaces Audio output xfrmr in a pinch
10/13/2007 3:07:53 AMPeter G. Balazsy
Undr the heading of Tips & Tricks:
I was browsing around the "AA5 Hot-rodding site" and came across a nice tip:
You can use a 6.3v CT Filament transformer in place of your audio output transformer if it's bad.
You can use the 6.3v winding with an 8 ohm speaker and the 3.2v tap for a 4 ohm speaker. .. Or whichever seems to give the best results as you test it... also depends if you are using a 50C5 or a 41 or 6v6 etc.
I tried this tonight with very good results on the output of a 50L6.
It even worked quite well with an old 120/10 vac door-bell chime transformer.
Here's the site:
http://www.geocities.com/wa2ise/radios/repair.htm#if
Here's the excerpt:
"Audio output transformer bad? In a pinch, one can use a power transformer with a secondary of 6.3V center-tap. The turns ratio of the 120V primary to 6.3V secondary is 20 to one. With an 8 ohm speaker as load, that works out to be 8*(202)=3200 ohms on the primary side, close enough to the 2500 ohms a 50C5 wants to drive. Output power will be a dB or so lower, but that will be not noticeable. If driving a 3.2 ohm speaker, use half of the secondary, ie, 3.15V. That's from one end to the center tap. That will look like 3.2*(402)=5120 ohms. Kinda high, but the output power will be half the original value. But you'll be back "on the air". Changing the speaker to an 8 ohm one would probably be worth the effort here. The frequency response of a power transformer will be adequate for an AA5 radio, but won't be hi-fi."
10/15/2007 9:16:06 AMRadiodoc
Peter,
I even saw/read somewhere a while ago where a person used an automotive ignition coil as an audio output transformer. I tried it and I was surprised at how it sounded, however I don't think I would use an ignition coil for permanent fix though.
:Undr the heading of Tips & Tricks:
:I was browsing around the "AA5 Hot-rodding site" and came across a nice tip:
:You can use a 6.3v CT Filament transformer in place of your audio output transformer if it's bad.
:You can use the 6.3v winding with an 8 ohm speaker and the 3.2v tap for a 4 ohm speaker. .. Or whichever seems to give the best results as you test it... also depends if you are using a 50C5 or a 41 or 6v6 etc.
:I tried this tonight with very good results on the output of a 50L6.
:It even worked quite well with an old 120/10 vac door-bell chime transformer.
:Here's the site:
:http://www.geocities.com/wa2ise/radios/repair.htm#if
:Here's the excerpt:
:"Audio output transformer bad? In a pinch, one can use a power transformer with a secondary of 6.3V center-tap. The turns ratio of the 120V primary to 6.3V secondary is 20 to one. With an 8 ohm speaker as load, that works out to be 8*(202)=3200 ohms on the primary side, close enough to the 2500 ohms a 50C5 wants to drive. Output power will be a dB or so lower, but that will be not noticeable. If driving a 3.2 ohm speaker, use half of the secondary, ie, 3.15V. That's from one end to the center tap. That will look like 3.2*(402)=5120 ohms. Kinda high, but the output power will be half the original value. But you'll be back "on the air". Changing the speaker to an 8 ohm one would probably be worth the effort here. The frequency response of a power transformer will be adequate for an AA5 radio, but won't be hi-fi."
10/15/2007 1:46:02 PMemustoe
Not knowing any better, I have been doing this since I was in my teens. At age 62, I still build a lot of my own stuff using salvaged parts. If you are willing to sacrifice high-frequency response, almost any 120 in to 5-20 volts out will 'work' as an output transformer. Any old power transformer from an old vibrator type car radio works GREAT with enhanced bass, using a pair or quad of 6V6-GT in push-pull. An old TV transformer, high voltage winding to push-pull 807 or 6L6-GC tubes makes a POWERFUL guitar amp with enhanced bass response. (But don't plug the guitar in with the amp turned up, or you will blow the speaker cone right through the grill cloth.)
:Peter,
:I even saw/read somewhere a while ago where a person used an automotive ignition coil as an audio output transformer. I tried it and I was surprised at how it sounded, however I don't think I would use an ignition coil for permanent fix though.
:Radiodoc
::Undr the heading of Tips & Tricks:
::I was browsing around the "AA5 Hot-rodding site" and came across a nice tip:
::You can use a 6.3v CT Filament transformer in place of your audio output transformer if it's bad.
::You can use the 6.3v winding with an 8 ohm speaker and the 3.2v tap for a 4 ohm speaker. .. Or whichever seems to give the best results as you test it... also depends if you are using a 50C5 or a 41 or 6v6 etc.
::I tried this tonight with very good results on the output of a 50L6.
::It even worked quite well with an old 120/10 vac door-bell chime transformer.
::Here's the site:
::http://www.geocities.com/wa2ise/radios/repair.htm#if
::Here's the excerpt:
::"Audio output transformer bad? In a pinch, one can use a power transformer with a secondary of 6.3V center-tap. The turns ratio of the 120V primary to 6.3V secondary is 20 to one. With an 8 ohm speaker as load, that works out to be 8*(202)=3200 ohms on the primary side, close enough to the 2500 ohms a 50C5 wants to drive. Output power will be a dB or so lower, but that will be not noticeable. If driving a 3.2 ohm speaker, use half of the secondary, ie, 3.15V. That's from one end to the center tap. That will look like 3.2*(402)=5120 ohms. Kinda high, but the output power will be half the original value. But you'll be back "on the air". Changing the speaker to an 8 ohm one would probably be worth the effort here. The frequency response of a power transformer will be adequate for an AA5 radio, but won't be hi-fi."
10/15/2007 2:04:28 PMThomas Dermody
Interesting about the flyback transformer. It uses a ferrite core, too, so it's really quite efficient.
I used to use filament transformers for output transformers all the time. They are sometimes quite plentiful at American Science and Surplus. I made my brother a small portable AA5 guitar amplifier, complete with vibrato, using an AC transformer as an output transformer (35Z5-rect, 50L6-output, 12SQ7-1st audio, 12SK7-pre-amp, 12SA7-vibrato). It's a shame that I used to build on wooden chassis, because I had to filter quite a bit to prevent spurious high frequency oscillation. I usually got pretty good results, though. Ah....back in the days of no responsibilities. I'd spend hours and days making various things. Any tube or transformer would do the trick. I built an amplifier once with a damper tube, a HOT, and some vertical triode....all old 1950s octal TV tubes. I didn't realize back then that those tubes don't necessarily operate linearily. The amplifier worked well enough, though. I've heard worse. Those tubes drew a lot of filament current.
10/15/2007 3:07:19 PMEdd
"An old TV transformer, high voltage winding to push-pull 807 or 6L6-GC tubes makes a POWERFUL guitar amp with enhanced bass response. "
OF COURSE.....he's referring to the use of a sets power transformer" not the hoz sweep components flyback transformer, with its optimal 15,750~'s design center
....as any very lower audio spectra would be down -60-80 db in any attempted trial to be used in that manner.
:Interesting about the flyback transformer. It uses a ferrite core, too, so it's really quite efficient.
:I used to use filament transformers for output transformers all the time. They are sometimes quite plentiful at American Science and Surplus. I made my brother a small portable AA5 guitar amplifier, complete with vibrato, using an AC transformer as an output transformer (35Z5-rect, 50L6-output, 12SQ7-1st audio, 12SK7-pre-amp, 12SA7-vibrato). It's a shame that I used to build on wooden chassis, because I had to filter quite a bit to prevent spurious high frequency oscillation. I usually got pretty good results, though. Ah....back in the days of no responsibilities. I'd spend hours and days making various things. Any tube or transformer would do the trick. I built an amplifier once with a damper tube, a HOT, and some vertical triode....all old 1950s octal TV tubes. I didn't realize back then that those tubes don't necessarily operate linearily. The amplifier worked well enough, though. I've heard worse. Those tubes drew a lot of filament current.
:T.
10/15/2007 8:48:15 PMThomas Dermody
Ah. Television power transformers are massive, but then, so are most guitar amplifier output transformers. It sure must put out some powerful sound!
10/16/2007 6:46:58 AMJon
:Not knowing any better, I have been doing this since I was in my teens. At age 62, I still build a lot of my own stuff using salvaged parts. If you are willing to sacrifice high-frequency response, almost any 120 in to 5-20 volts out will 'work' as an output transformer. Any old power transformer from an old vibrator type car radio works GREAT with enhanced bass, using a pair or quad of 6V6-GT in push-pull. An old TV transformer, high voltage winding to push-pull 807 or 6L6-GC tubes makes a POWERFUL guitar amp with enhanced bass response. (But don't plug the guitar in with the amp turned up, or you will blow the speaker cone right through the grill cloth.)
How can I get a schematic for one of these guitar amps? I would love to build one for my son.
Jon.
::Peter,
::I even saw/read somewhere a while ago where a person used an automotive ignition coil as an audio output transformer. I tried it and I was surprised at how it sounded, however I don't think I would use an ignition coil for permanent fix though.
::Radiodoc
:::Undr the heading of Tips & Tricks:
:::I was browsing around the "AA5 Hot-rodding site" and came across a nice tip:
:::You can use a 6.3v CT Filament transformer in place of your audio output transformer if it's bad.
:::You can use the 6.3v winding with an 8 ohm speaker and the 3.2v tap for a 4 ohm speaker. .. Or whichever seems to give the best results as you test it... also depends if you are using a 50C5 or a 41 or 6v6 etc.
:::I tried this tonight with very good results on the output of a 50L6.
:::It even worked quite well with an old 120/10 vac door-bell chime transformer.
:::Here's the site:
:::http://www.geocities.com/wa2ise/radios/repair.htm#if
:::Here's the excerpt:
:::"Audio output transformer bad? In a pinch, one can use a power transformer with a secondary of 6.3V center-tap. The turns ratio of the 120V primary to 6.3V secondary is 20 to one. With an 8 ohm speaker as load, that works out to be 8*(202)=3200 ohms on the primary side, close enough to the 2500 ohms a 50C5 wants to drive. Output power will be a dB or so lower, but that will be not noticeable. If driving a 3.2 ohm speaker, use half of the secondary, ie, 3.15V. That's from one end to the center tap. That will look like 3.2*(402)=5120 ohms. Kinda high, but the output power will be half the original value. But you'll be back "on the air". Changing the speaker to an 8 ohm one would probably be worth the effort here. The frequency response of a power transformer will be adequate for an AA5 radio, but won't be hi-fi."
10/16/2007 10:49:22 AMEdd
Decisions....decisions...decisions.....Just make your choice...you should find just about any famous tube amp of renown from the past within this collection.
Just click ... and pick....... http://www.drtube.com/guitamp.htm
::Not knowing any better, I have been doing this since I was in my teens. At age 62, I still build a lot of my own stuff using salvaged parts. If you are willing to sacrifice high-frequency response, almost any 120 in to 5-20 volts out will 'work' as an output transformer. Any old power transformer from an old vibrator type car radio works GREAT with enhanced bass, using a pair or quad of 6V6-GT in push-pull. An old TV transformer, high voltage winding to push-pull 807 or 6L6-GC tubes makes a POWERFUL guitar amp with enhanced bass response. (But don't plug the guitar in with the amp turned up, or you will blow the speaker cone right through the grill cloth.)
:How can I get a schematic for one of these guitar amps? I would love to build one for my son.
:Jon.
:::Peter,
:::I even saw/read somewhere a while ago where a person used an automotive ignition coil as an audio output transformer. I tried it and I was surprised at how it sounded, however I don't think I would use an ignition coil for permanent fix though.
:::Radiodoc
::::Undr the heading of Tips & Tricks:
::::I was browsing around the "AA5 Hot-rodding site" and came across a nice tip:
::::You can use a 6.3v CT Filament transformer in place of your audio output transformer if it's bad.
::::You can use the 6.3v winding with an 8 ohm speaker and the 3.2v tap for a 4 ohm speaker. .. Or whichever seems to give the best results as you test it... also depends if you are using a 50C5 or a 41 or 6v6 etc.
::::I tried this tonight with very good results on the output of a 50L6.
::::It even worked quite well with an old 120/10 vac door-bell chime transformer.
::::Here's the site:
::::http://www.geocities.com/wa2ise/radios/repair.htm#if
::::Here's the excerpt:
::::"Audio output transformer bad? In a pinch, one can use a power transformer with a secondary of 6.3V center-tap. The turns ratio of the 120V primary to 6.3V secondary is 20 to one. With an 8 ohm speaker as load, that works out to be 8*(202)=3200 ohms on the primary side, close enough to the 2500 ohms a 50C5 wants to drive. Output power will be a dB or so lower, but that will be not noticeable. If driving a 3.2 ohm speaker, use half of the secondary, ie, 3.15V. That's from one end to the center tap. That will look like 3.2*(402)=5120 ohms. Kinda high, but the output power will be half the original value. But you'll be back "on the air". Changing the speaker to an 8 ohm one would probably be worth the effort here. The frequency response of a power transformer will be adequate for an AA5 radio, but won't be hi-fi."
10/16/2007 6:14:39 PMJon
:Decisions....decisions...decisions.....Just make your choice...you should find just about any famous tube amp of renown from the past within this collection.
:Just click ... and pick....... http://www.drtube.com/guitamp.htm
Edd, Thanks for the link you are right, where to start?
Jon.:
:::Not knowing any better, I have been doing this since I was in my teens. At age 62, I still build a lot of my own stuff using salvaged parts. If you are willing to sacrifice high-frequency response, almost any 120 in to 5-20 volts out will 'work' as an output transformer. Any old power transformer from an old vibrator type car radio works GREAT with enhanced bass, using a pair or quad of 6V6-GT in push-pull. An old TV transformer, high voltage winding to push-pull 807 or 6L6-GC tubes makes a POWERFUL guitar amp with enhanced bass response. (But don't plug the guitar in with the amp turned up, or you will blow the speaker cone right through the grill cloth.)
::How can I get a schematic for one of these guitar amps? I would love to build one for my son.
::Jon.
::::Peter,
::::I even saw/read somewhere a while ago where a person used an automotive ignition coil as an audio output transformer. I tried it and I was surprised at how it sounded, however I don't think I would use an ignition coil for permanent fix though.
::::Radiodoc
:::::Undr the heading of Tips & Tricks:
:::::I was browsing around the "AA5 Hot-rodding site" and came across a nice tip:
:::::You can use a 6.3v CT Filament transformer in place of your audio output transformer if it's bad.
:::::You can use the 6.3v winding with an 8 ohm speaker and the 3.2v tap for a 4 ohm speaker. .. Or whichever seems to give the best results as you test it... also depends if you are using a 50C5 or a 41 or 6v6 etc.
:::::I tried this tonight with very good results on the output of a 50L6.
:::::It even worked quite well with an old 120/10 vac door-bell chime transformer.
:::::Here's the site:
:::::http://www.geocities.com/wa2ise/radios/repair.htm#if
:::::Here's the excerpt:
:::::"Audio output transformer bad? In a pinch, one can use a power transformer with a secondary of 6.3V center-tap. The turns ratio of the 120V primary to 6.3V secondary is 20 to one. With an 8 ohm speaker as load, that works out to be 8*(202)=3200 ohms on the primary side, close enough to the 2500 ohms a 50C5 wants to drive. Output power will be a dB or so lower, but that will be not noticeable. If driving a 3.2 ohm speaker, use half of the secondary, ie, 3.15V. That's from one end to the center tap. That will look like 3.2*(402)=5120 ohms. Kinda high, but the output power will be half the original value. But you'll be back "on the air". Changing the speaker to an 8 ohm one would probably be worth the effort here. The frequency response of a power transformer will be adequate for an AA5 radio, but won't be hi-fi."
