I just purchased a FADA Bullet 1000 from Ebay. After recieving it I found that the chassis inside had a tube line-up of 50L6, 34W4, 12BA6, 12BA6, 12BE6 and 12AT6. Can someone tell me if this chasis is from another radio?
Greg
Hi Dennis, Thats what I thought. The chassis itself is the same as my other Bullet 1000 but the tubes are different. Any idea what this tube line-up could be for?
Greg
Didn't see any FADA's with this tube line up in Mallory's. Any identifier's on the chassis?
Carl T
The chassis has the numbers 18977C stamped on it. My other bullet has 1000 stamped on it. I guess I'm going to try to work with whats there and try to get her running. Its strange because all the locations ot the coils, tubes, speaker, dial and tuning condensor in the exact position as my other Bullet.
If anyoune out there has any additional information please send it my way.
Greg
:::A Fada 1000 uses a 35Z5, 12SK7 (x2), 12SA7, 12SQ7 & 35L6
::Hi Dennis, Thats what I thought. The chassis itself is the same as my other Bullet 1000 but the tubes are different. Any idea what this tube line-up could be for?
::Thanks
::Greg
:Didn't see any FADA's with this tube line up in Mallory's. Any identifier's on the chassis?
:Carl T
Greg,
Click on my name above and e-mail me. I can e-mail you a schematic for a Fada 700 that has all of the correct tubes except for the output. It uses a 35B5 instead of the 50L6.
Carl T
I had a Crosley 10-137 which was supposed to have the modern miniature tube lineup - and mine did, except that the 12AV6 position held a 12SQ7 octal, with no evidence of any rework. If I recall - the tube chart on the bottom of the radio may even have shown a 12AV6 here. Apparently - it was not uncommon for some manufacturers to make substitutions when convenient.
Greg,
There were apperently several versions of the 1000 chassis, 1 similar to the 700.
Carl T
