It might be an electron relay.
I think the E. R. is for Eveready Raytheon.
Bill
That appears to be a triode from the 1920's or perhaps earlier. The bayonet base with 4 pins looks like a tube from that era. I don't remember having seen that particular glass envelope though.
It has to be somewhere in between the DeForest Audion and 01a.
Can you see a grid in this tube? If not it might be an early rectifier?
I'll send this to Tube Collectors Association. Jim Cross or Lud Sibley might know?
:::::This tube has E. R. 507255 on the bulb and only an "S" near the pins. No other markings. What is it?
:::::Bill
::::It might be an electron relay.
:::I think the E. R. is for Eveready Raytheon.
:::Bill
::That appears to be a triode from the 1920's or perhaps earlier. The bayonet base with 4 pins looks like a tube from that era. I don't remember having seen that particular glass envelope though.
:It has to be somewhere in between the DeForest Audion and 01a.
:Bill
: Can you see a grid in this tube? If not it might be an early rectifier?
: I'll send this to Tube Collectors Association. Jim Cross or Lud Sibley might know?
::::::This tube has E. R. 507255 on the bulb and only an "S" near the pins. No other markings. What is it?
::::::Bill
:::::It might be an electron relay.
::::I think the E. R. is for Eveready Raytheon.
::::Bill
:::That appears to be a triode from the 1920's or perhaps earlier. The bayonet base with 4 pins looks like a tube from that era. I don't remember having seen that particular glass envelope though.
::It has to be somewhere in between the DeForest Audion and 01a.
http://www.bill01a.com/articles/moorhead.htm#_edn39
:Norm, It's a Moorhead Electron Relay tube. I was reading about reactivating old tubes in "Everyman's Guide to Radio" 1927, and stumbled upon a picture. Guess that's what Johnnysan was indicating. The web has sites with pictures and data about Moorhead I need to read yet. But a detector? Thanks to all for the help. Any other specifics appreciated.
:Bill
::Bill
:: Can you see a grid in this tube? If not it might be an early rectifier?
:: I'll send this to Tube Collectors Association. Jim Cross or Lud Sibley might know?
:::::::This tube has E. R. 507255 on the bulb and only an "S" near the pins. No other markings. What is it?
:::::::Bill
::::::It might be an electron relay.
:::::I think the E. R. is for Eveready Raytheon.
:::::Bill
::::That appears to be a triode from the 1920's or perhaps earlier. The bayonet base with 4 pins looks like a tube from that era. I don't remember having seen that particular glass envelope though.
:::It has to be somewhere in between the DeForest Audion and 01a.
Heard back from Lud. Tube was made around 1920 in San Francisco. The 6 digit number is the serial. The S probably indicates Shaw base. Lud called it an "electron relay".
I would have forwarded the email but your address isn't shown.
I got it now. It's a gas detector. Moorhead ER tall plate with mica spacer, 7,000 made. Filament volts 4, current .70, and plate 20-40 volts.Information from this site:
:http://www.bill01a.com/articles/moorhead.htm#_edn39
::Norm, It's a Moorhead Electron Relay tube. I was reading about reactivating old tubes in "Everyman's Guide to Radio" 1927, and stumbled upon a picture. Guess that's what Johnnysan was indicating. The web has sites with pictures and data about Moorhead I need to read yet. But a detector? Thanks to all for the help. Any other specifics appreciated.
::Bill
:::Bill
::: Can you see a grid in this tube? If not it might be an early rectifier?
::: I'll send this to Tube Collectors Association. Jim Cross or Lud Sibley might know?
::::::::This tube has E. R. 507255 on the bulb and only an "S" near the pins. No other markings. What is it?
::::::::Bill
:::::::It might be an electron relay.
::::::I think the E. R. is for Eveready Raytheon.
::::::Bill
:::::That appears to be a triode from the 1920's or perhaps earlier. The bayonet base with 4 pins looks like a tube from that era. I don't remember having seen that particular glass envelope though.
::::It has to be somewhere in between the DeForest Audion and 01a.
:Bill
: Heard back from Lud. Tube was made around 1920 in San Francisco. The 6 digit number is the serial. The S probably indicates Shaw base. Lud called it an "electron relay".
: I would have forwarded the email but your address isn't shown.
:I got it now. It's a gas detector. Moorhead ER tall plate with mica spacer, 7,000 made. Filament volts 4, current .70, and plate 20-40 volts.Information from this site:
::http://www.bill01a.com/articles/moorhead.htm#_edn39
:::Norm, It's a Moorhead Electron Relay tube. I was reading about reactivating old tubes in "Everyman's Guide to Radio" 1927, and stumbled upon a picture. Guess that's what Johnnysan was indicating. The web has sites with pictures and data about Moorhead I need to read yet. But a detector? Thanks to all for the help. Any other specifics appreciated.
:::Bill
::::Bill
:::: Can you see a grid in this tube? If not it might be an early rectifier?
:::: I'll send this to Tube Collectors Association. Jim Cross or Lud Sibley might know?
::::Norm
:::::::::This tube has E. R. 507255 on the bulb and only an "S" near the pins. No other markings. What is it?
:::::::::Bill
::::::::It might be an electron relay.
:::::::I think the E. R. is for Eveready Raytheon.
:::::::Bill
::::::That appears to be a triode from the 1920's or perhaps earlier. The bayonet base with 4 pins looks like a tube from that era. I don't remember having seen that particular glass envelope though.
:::::It has to be somewhere in between the DeForest Audion and 01a.
Email forwarded.
:Thanks Norm. I put my email address up.
:Bill
::Bill
:: Heard back from Lud. Tube was made around 1920 in San Francisco. The 6 digit number is the serial. The S probably indicates Shaw base. Lud called it an "electron relay".
:: I would have forwarded the email but your address isn't shown.
::I got it now. It's a gas detector. Moorhead ER tall plate with mica spacer, 7,000 made. Filament volts 4, current .70, and plate 20-40 volts.Information from this site:
:::http://www.bill01a.com/articles/moorhead.htm#_edn39
::::Norm, It's a Moorhead Electron Relay tube. I was reading about reactivating old tubes in "Everyman's Guide to Radio" 1927, and stumbled upon a picture. Guess that's what Johnnysan was indicating. The web has sites with pictures and data about Moorhead I need to read yet. But a detector? Thanks to all for the help. Any other specifics appreciated.
::::Bill
:::::Bill
::::: Can you see a grid in this tube? If not it might be an early rectifier?
::::: I'll send this to Tube Collectors Association. Jim Cross or Lud Sibley might know?
:::::Norm
::::::::::This tube has E. R. 507255 on the bulb and only an "S" near the pins. No other markings. What is it?
::::::::::Bill
:::::::::It might be an electron relay.
::::::::I think the E. R. is for Eveready Raytheon.
::::::::Bill
:::::::That appears to be a triode from the 1920's or perhaps earlier. The bayonet base with 4 pins looks like a tube from that era. I don't remember having seen that particular glass envelope though.
::::::It has to be somewhere in between the DeForest Audion and 01a.
