Sears 1725 Power transformer has 4 secondary windings. You need 5 volts @ 2 amps for the rectifier (83V). You need 2.5 volts @ 3 amps for 45 tubes. Other tubes require 6.3 volts @ 1.5 amps or more.
High voltage should be around 350-0-350 @ 70 ma or more. DC output is shown as 390 volts. Voltage on this winding isn't critical. 300-0-300 will be ok.
http://www.nostalgiaair.org/PagesByModel/733/M0016733.pdf
Thransformers with 2.5 and 6.3 volt windings aren't common. Might find something at PTOP? Here is their list:
:I just got this Silvertone console Model 1725 and the power transformer is bad. What would the specs. be for a replacement?
::Hi John
:: Sears 1725 Power transformer has 4 secondary windings. You need 5 volts @ 2 amps for the rectifier (83V). You need 2.5 volts @ 3 amps for 45 tubes. Other tubes require 6.3 volts @ 1.5 amps or more.
:: High voltage should be around 350-0-350 @ 70 ma or more. DC output is shown as 390 volts. Voltage on this winding isn't critical. 300-0-300 will be ok.
::http://www.nostalgiaair.org/PagesByModel/733/M0016733.pdf
:: Thransformers with 2.5 and 6.3 volt windings aren't common. Might find something at PTOP? Here is their list:
::http://www.oldradioparts.com/2a23efl.txt
:::I just got this Silvertone console Model 1725 and the power transformer is bad. What would the specs. be for a replacement?
