You can check out:
http://www.genesislamp.com/14milibu26.html
http://www.lightbulbemporium.com/proddetail.asp?prod=751310
:I am looking for dial lamps for the RCA 2X61. The lamps are Mazada type 1490 3.2 volts .15 amps. I have looked at Antique Electronic Supply and Radio Daze. Neither has this. Any suggestions where to get these? Would it be okay to replace them with another dial lamp?
:Thanks,
:Steve
You shouldn't use other lamps. In a radio like this two lamps will be in series along with tubes drawing .15 amps filament current.
Radios like this usually have a #47 lamp rated 6 volts @ .15 amps. Since you have two in series both should be rated 3.2 @ .15 amps.
I buy 1490's from www.bulbdirect.com .
:Steve,
:You can check out:
:http://www.genesislamp.com/14milibu26.html
:http://www.lightbulbemporium.com/proddetail.asp?prod=751310
:Radiodoc
::I am looking for dial lamps for the RCA 2X61. The lamps are Mazada type 1490 3.2 volts .15 amps. I have looked at Antique Electronic Supply and Radio Daze. Neither has this. Any suggestions where to get these? Would it be okay to replace them with another dial lamp?
::Thanks,
::Steve
Steve
:Steve
: You shouldn't use other lamps. In a radio like this two lamps will be in series along with tubes drawing .15 amps filament current.
: Radios like this usually have a #47 lamp rated 6 volts @ .15 amps. Since you have two in series both should be rated 3.2 @ .15 amps.
: I buy 1490's from www.bulbdirect.com .
::Steve,
::You can check out:
::http://www.genesislamp.com/14milibu26.html
::http://www.lightbulbemporium.com/proddetail.asp?prod=751310
::Radiodoc
:::I am looking for dial lamps for the RCA 2X61. The lamps are Mazada type 1490 3.2 volts .15 amps. I have looked at Antique Electronic Supply and Radio Daze. Neither has this. Any suggestions where to get these? Would it be okay to replace them with another dial lamp?
:::Thanks,
:::Steve
