Philco Model 17 - Mystery?
9/29/2007 3:07:21 PMJim Price
I have a console that's labeled Model 17 Code 125 - Part Number 39-5962. This is not the Model 17 from the early 30's as it has a 5 tube chasis (6A7, 78, 75, 84, 41), not the 11 tube chasis of the early 30's model. I've seen on the web similar a chasis in a table model. There's a rectangular dial above 3 knobs and 6 push buttons below that. Does anyone know anything about this radio? So far everyone I've contacted or has seen the radio had never seen it before.
9/29/2007 6:16:48 PMNorm Leal
Jim
You most likely have a chassis from a different cabinet? Check out Model 39-25 or 39-17. Using an 84 for rectifier was common for Philco in 1939.
http://www.nostalgiaair.org/Resources/303/T0000303.htm
:I have a console that's labeled Model 17 Code 125 - Part Number 39-5962. This is not the Model 17 from the early 30's as it has a 5 tube chasis (6A7, 78, 75, 84, 41), not the 11 tube chasis of the early 30's model. I've seen on the web similar a chasis in a table model. There's a rectangular dial above 3 knobs and 6 push buttons below that. Does anyone know anything about this radio? So far everyone I've contacted or has seen the radio had never seen it before.
:Thanks
10/4/2007 8:29:42 PMJim Price
:Jim
: You most likely have a chassis from a different cabinet? Check out Model 39-25 or 39-17. Using an 84 for rectifier was common for Philco in 1939.
:http://www.nostalgiaair.org/Resources/303/T0000303.htm
::I have a console that's labeled Model 17 Code 125 - Part Number 39-5962. This is not the Model 17 from the early 30's as it has a 5 tube chasis (6A7, 78, 75, 84, 41), not the 11 tube chasis of the early 30's model. I've seen on the web similar a chasis in a table model. There's a rectangular dial above 3 knobs and 6 push buttons below that. Does anyone know anything about this radio? So far everyone I've contacted or has seen the radio had never seen it before.
::Thanks
10/4/2007 8:33:52 PMJim Price
Thanks Norman, I found one that looks just like mine (I couldn't tell if the pushbuttons were there) on philcoradio.com labeled as a 38-17F. Do you have any idea what it might be worth if restored?
Thanks Again,
Jim
::Jim
:: You most likely have a chassis from a different cabinet? Check out Model 39-25 or 39-17. Using an 84 for rectifier was common for Philco in 1939.
::http://www.nostalgiaair.org/Resources/303/T0000303.htm
:::I have a console that's labeled Model 17 Code 125 - Part Number 39-5962. This is not the Model 17 from the early 30's as it has a 5 tube chasis (6A7, 78, 75, 84, 41), not the 11 tube chasis of the early 30's model. I've seen on the web similar a chasis in a table model. There's a rectangular dial above 3 knobs and 6 push buttons below that. Does anyone know anything about this radio? So far everyone I've contacted or has seen the radio had never seen it before.
:::Thanks
10/5/2007 10:46:12 AMNorm Leal
Jim
Philco 39-17F is shown in Collectors Guide to Antique Radios as being worth $120-$150.
This doesn't mean it can be sold at that price. They are really worth what a person is willing to spend. Garage sales, not much, antique stores high.
:Thanks Norman, I found one that looks just like mine (I couldn't tell if the pushbuttons were there) on philcoradio.com labeled as a 38-17F. Do you have any idea what it might be worth if restored?
:Thanks Again,
:Jim
:::Jim
::: You most likely have a chassis from a different cabinet? Check out Model 39-25 or 39-17. Using an 84 for rectifier was common for Philco in 1939.
:::http://www.nostalgiaair.org/Resources/303/T0000303.htm
::::I have a console that's labeled Model 17 Code 125 - Part Number 39-5962. This is not the Model 17 from the early 30's as it has a 5 tube chasis (6A7, 78, 75, 84, 41), not the 11 tube chasis of the early 30's model. I've seen on the web similar a chasis in a table model. There's a rectangular dial above 3 knobs and 6 push buttons below that. Does anyone know anything about this radio? So far everyone I've contacted or has seen the radio had never seen it before.
::::Thanks
