testing primary antenna coil Philco 37-38
9/28/2007 12:41:21 PMBrian
Can someone explain how I can measure continuity on primary of the antenna coil for this radio? I take it it is a matter of measuring the contacts on the band switch, but I need a little guidance in following the schematic and applying to the radio.
9/28/2007 1:15:45 PMRadiodoc
Brian,
You should be able to measure the primary of the broadcast and shortwave RF coils by measuring the resistance between the A and G terminals. The schematic shows the range switch in position 1 (broadcast). You should measure close to the values on the schematic. With the ohmmeter still on A & G switch to position 2 and you should measure that RF coil.
:Can someone explain how I can measure continuity on primary of the antenna coil for this radio? I take it it is a matter of measuring the contacts on the band switch, but I need a little guidance in following the schematic and applying to the radio.
