:Hi everyone,I own an s-40a that I have been debugging for some time now.I have managed to cure all it's problems but one has reared its ugly head that I just don't have the experience to conquer.I have recently found that if I turn up the volume on a strong station the receiver begins to growl or exibit feedback if you will.I never noticed this problem until now because I have a tendency to listen at low volume seeing as though the speaker is only about a foot from my ear.I have found however that if I loosen the speaker mounting bolts and let it hang in the rubber grommets,the growling stops.Therefore I assume the problem involves vibration from the speaker.I replaced all the tubes to see if a microphonic one was the problem but it still growls.I checked underneath to see if applying pressure to any of the components would help.Still growls.
: Just for giggles I took some resistance readings at the first and second audio tubes.I found that the grid resistor on the first audio tube(6sq7) was way out of spec.It is supposed to be a 15 meg,but measures just under 24.Would this cause the feedback problem by altering the gain of the first audio tube?I read somewhere that this can cause the tube to become some sort of oscillator under the right conditions.Maybe I'm just crazy.Would love to get this problem straightened out and finally call this radio done.Any suggestions would be greatly appreciated.Thanx.
:Thank you Marv for the comments.I had the same ideas about speaker placement and so forth and how to dampen the vibrations.I exaggerated a tad when I said that hanging the speaker loosely from the grommets stopped the feedback.What I should have said is that it lessened it a bit.Holding the speaker in my hand inside the cabinet still produces the feedback as long as the sound waves can contact it.I have checked it over very thoroughly,there are no loose parts anywhere rattling.I feel that Jim's suspicion of the grid load resistor is the culprit.I had to go to the local tv repair shop to get one of such high value.I paid over two bucks for that resistor,that shows you how much I would like to finish this rig.He didn't offer me any Vaseline to go with it,unfortunately.Thanx.
Make sure the tuning capacitor isolation grommets have not lost their resiliency. My S40 howled until I replaced all of the isolation rubber. Ordinary grommets may be too hard. It has been a while but I think that I used some soft grommets from a defunct CD player.
