Schematic Bank
9/22/2007 10:25:01 PMBill VA
For some reason I can't view schematics on the schematic bank. I've unstalled and reinstalled the viewer over and over. Just get blank page. Never had problems before. Just me?
Bill
9/22/2007 10:34:16 PMNorm Leal
Hi Bill
I just tried and it worked for me. Can you view the following:
http://techpreservation.dyndns.org/schematics/38/38_Atwater%20Kent_40_10.djvu
:For some reason I can't view schematics on the schematic bank. I've unstalled and reinstalled the viewer over and over. Just get blank page. Never had problems before. Just me?
:Bill
9/22/2007 10:48:53 PMBill VA
No Norm, I get same blank page. I can select maker and then model but then up comes the blank page.
Bill
Hi Bill
: I just tried and it worked for me. Can you view the following:
:http://techpreservation.dyndns.org/schematics/38/38_Atwater%20Kent_40_10.djvu
::For some reason I can't view schematics on the schematic bank. I've unstalled and reinstalled the viewer over and over. Just get blank page. Never had problems before. Just me?
::Bill
9/23/2007 10:19:10 AMCarl T
:No Norm, I get same blank page. I can select maker and then model but then up comes the blank page.
:Bill
Bill,
Could be the security settings for your browser.
Which operating system and browser are you using?
Do you get a warning at the top of the page about active x?
Carl T
:Hi Bill
:: I just tried and it worked for me. Can you view the following:
::http://techpreservation.dyndns.org/schematics/38/38_Atwater%20Kent_40_10.djvu
:::For some reason I can't view schematics on the schematic bank. I've unstalled and reinstalled the viewer over and over. Just get blank page. Never had problems before. Just me?
:::Bill
9/23/2007 2:11:44 PMBill VA
::No Norm, I get same blank page. I can select maker and then model but then up comes the blank page.
::Bill
:Bill,
:Could be the security settings for your browser.
:Which operating system and browser are you using?
:Do you get a warning at the top of the page about active x?
:Carl T
Carl, I have XP and IE 7. I kept getting the "do you want to run or save" over and over. I could try either and same message came back up. I then unstalled the djv and installed WinDjView ( three tries) and could download but when I opened to view schematic, got blank document? Now I have taken WinDjView off my computer. I may try the viewer again. I have schematic bank as trusted site. Some quirky thing happened and I got to correct it.
Bill
::Hi Bill
::: I just tried and it worked for me. Can you view the following:
:::http://techpreservation.dyndns.org/schematics/38/38_Atwater%20Kent_40_10.djvu
::::For some reason I can't view schematics on the schematic bank. I've unstalled and reinstalled the viewer over and over. Just get blank page. Never had problems before. Just me?
::::Bill
9/23/2007 8:30:34 PMCarl T
::Bill,
::Could be the security settings for your browser.
::Which operating system and browser are you using?
::Do you get a warning at the top of the page about active x?
::Carl T
:Carl, I have XP and IE 7. I kept getting the "do you want to run or save" over and over. I could try either and same message came back up. I then unstalled the djv and installed WinDjView ( three tries) and could download but when I opened to view schematic, got blank document? Now I have taken WinDjView off my computer. I may try the viewer again. I have schematic bank as trusted site. Some quirky thing happened and I got to correct it.
:Bill
I am also running XP with IE7. I have the Lizardtech plug-in installed for viewing DJVU files:
http://www.lizardtech.com/download/dl_download.php?detail=doc_djvu_plugin&platform=win
I also have Irfanview instaled for opening saved files:
http://irfanview.com/
When I first began using XP with IE7, I would get a message at the top of the window about runing active x. Just click on it and accept running the control.
Hope this helps.
Carl T
9/23/2007 9:49:44 PMBill VA
:::Bill,
:::Could be the security settings for your browser.
:::Which operating system and browser are you using?
:::Do you get a warning at the top of the page about active x?
:::Carl T
::Carl, I have XP and IE 7. I kept getting the "do you want to run or save" over and over. I could try either and same message came back up. I then unstalled the djv and installed WinDjView ( three tries) and could download but when I opened to view schematic, got blank document? Now I have taken WinDjView off my computer. I may try the viewer again. I have schematic bank as trusted site. Some quirky thing happened and I got to correct it.
::Bill
:I am also running XP with IE7. I have the Lizardtech plug-in installed for viewing DJVU files:
:http://www.lizardtech.com/download/dl_download.php?detail=doc_djvu_plugin&platform=win
:I also have Irfanview instaled for opening saved files:
:http://irfanview.com/
:When I first began using XP with IE7, I would get a message at the top of the window about runing active x. Just click on it and accept running the control.
:Hope this helps.
:Carl T
Thanks Carl and Norm for responding. Nobody else with problem, had to be me. Tho I don't know what happen, worked before. I did re-installed DJVU and now everything is just dandy.
Bill
