westinghouse wr-8 blown fuses
9/22/2007 12:43:39 AMira
Hi,hope someone can help.I have a Westinghouse WR-8 that I cannot get going.Everytime I replace the fuse,before current hits the power supply the fuse blows.Can someone help me figure what I am doing wrong? Thanks,Ira.
9/22/2007 4:22:01 AMJohnnysan
:Hi,hope someone can help.I have a Westinghouse WR-8 that I cannot get going.Everytime I replace the fuse,before current hits the power supply the fuse blows.Can someone help me figure what I am doing wrong? Thanks,Ira.
Remove the rectifier and power up slowly with a variac (if you have one) while measuring current draw. Use a dim bulb tester otherwise. If the current is still high, the power transformer is bad, or there is a short on the filament line.
9/30/2007 4:06:13 PMMmakazoo
Make sure that you are using "slow blow" fuse, not fast. Mark from Kalamazoo
9/30/2007 4:13:40 PMMmakazoo
Make sure you are using "slow-blow" fuse, not fast. Mark from Kalamazoo
5/24/2010 1:33:06 AMbruce
a i have 2 old time rodios one is a 1931 the same one you have mine works its up for sale & the other one is a zenith 10a1 radio call lee @ 717 495 3299 any time 24/7 ok they both r up for sale make me a offer ok
5/25/2010 12:08:32 AMTerry Decker
Johnnysan has the right idea. There is obviously a short somewhere. However, you can start at the other end too. Disconnect EVERYTHING from the line cord. Then add each item one at a time. It could be a shorted cord, solder bridge, wire connected wrong, etc. Always start a one end and methodically go one step at a time. I had a transformer that kept heating up. I started at the rectifier and puzzled about it for days. I figured the transformer was bad and went to toss it. Turned out the resistor in the filter section was barely touching the edge of the tube socket. A little heat shrink and I was good to go.
Terry
