tube substitution
9/21/2007 7:08:10 AMAymen
Hi all
i need to substitude my EB41 tube with modern components. can any one please help me by sending me the drawing of the replacing circuit.
thanks a ilion
the data sheet of the eb41 could be foud at this link
http://www.mif.pg.gda.pl/homepages/frank/sheets/030/e/EB41.pdf
9/21/2007 11:26:55 AMNorm Leal
Hi Aymen
If the EB41 is being used as a detector a 6AL5 will work. You would need to make an adapter.
Also check out 6H6 and 7A6. These tubes are older and may look more like your original.
http://www.mif.pg.gda.pl/homepages/frank/sheets/093/6/6AL5.pdf
http://www.mif.pg.gda.pl/homepages/frank/sheets/121/7/7A6.pdf
http://www.mif.pg.gda.pl/homepages/frank/sheets/093/6/6H6.pdf
:Hi all
:i need to substitude my EB41 tube with modern components. can any one please help me by sending me the drawing of the replacing circuit.
:thanks a ilion
:the data sheet of the eb41 could be foud at this link
:http://www.mif.pg.gda.pl/homepages/frank/sheets/030/e/EB41.pdf
9/21/2007 12:10:36 PMEdd
Since that is typically used as a detector diode .
How about going from the old ring lock base of that tube configuration, and not having to go to a larger octal or locktal sizing, and setting in a 7 pin miniature socket in its place and replace it with ye olde reliable...and ..very important....PLENTIFUL...6AL5...and not have to pay out ~ US $8 pricing for the current tube used.
Reference:
:Hi Aymen
: If the EB41 is being used as a detector a 6AL5 will work. You would need to make an adapter.
: Also check out 6H6 and 7A6. These tubes are older and may look more like your original.
:http://www.mif.pg.gda.pl/homepages/frank/sheets/093/6/6AL5.pdf
:http://www.mif.pg.gda.pl/homepages/frank/sheets/121/7/7A6.pdf
:http://www.mif.pg.gda.pl/homepages/frank/sheets/093/6/6H6.pdf
::Hi all
::i need to substitude my EB41 tube with modern components. can any one please help me by sending me the drawing of the replacing circuit.
::thanks a ilion
::the data sheet of the eb41 could be foud at this link
::http://www.mif.pg.gda.pl/homepages/frank/sheets/030/e/EB41.pdf
