___________________________________________________________________
Did you read the manual and set the tester up properly? Did you test the tube for shorts? You cannot test a shorted tube for emission. Does it do this with all the tubes you test? You may have something wired wrong, this is a simple tester and easy to trace the circuits using the schematic.
GO here and download the manual for it.
http://bama.edebris.com/manuals/heath/
The shorts bulb is a NE-51 neon bulb. Did the tester work before you repaired it?
Paul,
BAMA has a partial manual in DJVU format - no tube chart:
If you are not familiar with DJVU, read the bottom of the first page. A lot of guys use Irfanview.
Carl T
Now with a look at the short testing aspect (the highlighted fuscia loop) where you got to install "THE" capacitor in the unit. That is one point where you would want a higher voltage rated unit preferably, and ABSOLUTE minimal leakage in it. It grabs a static AC voltage level from the 100 VAC tap and provides DC isolation to then feed into the NE-51----NE-2 neon short indicator lamp. That lamp is using a resistive pre biasing arrangement to have it closer to its firing threshold,enhancing its short detection sensitivity. The testing line loop then passes on down to the function selector switch and passes on through its one involved contact, and then on down to one buss line on the bank of set up switches, which individually flip in for testing for any tube leakage / shorts.
Stopping for your evaluation and feedback.....
::::hello. i have a heathkit tc-1 tube tester. the tester works. when i pull the switch down to test the tube, it pins the neddle. i replaced the capacitor and all the resistors and sub out the meter. it still does the same thing. pins the needle. any ideas?
:::___________________________________________________________________
:::Did you read the manual and set the tester up properly? Did you test the tube for shorts? You cannot test a shorted tube for emission. Does it do this with all the tubes you test? You may have something wired wrong, this is a simple tester and easy to trace the circuits using the schematic.:____________________________:_______________________________WHEN I RECIEVED THE TESTER IT ONLY DID LINE TEST. ALL I DID WAS REPLACE ALL THE RESISTORS AND THE CAP ONE BY ONE. THEY ARE ALL THE CORRECT VALUES. I DO NOT HAVE ANY INFO ON THE TESTER.I ALSO REPLACED THE SHORT LIGHT WITH THE CORRECT BULB.NOW IT PINS THE NEEDLE.ALL THE TUBES CHECK GOOD ON MY PRECISION 10-12.IM WORKING ON GETTING A MANUAL FOR IT.
:Paul,
:BAMA has a partial manual in DJVU format - no tube chart:
:http://bama.edebris.com/manuals/
:If you are not familiar with DJVU, read the bottom of the first page. A lot of guys use Irfanview.
:Carl T
