Bill,
I buy most of my caps from Mouser.com
Another source with a good selection is justradios.com
Carl T
I have bought all ways.The BEST bargains he has there are the GREEN dipped Mylar caps... they are great quality and best prices.
http://www.justradios.com/MYLARcapacitors.html
:After my last radio redo, I'm running low on caps. I used to pick them up at shows or buy from Everett Hoard in North Dakota - but he's been threatening to quit for years and I don't know if he's still in the business. Who currently has the best deals and good service? All recommendations welcomed. Thanks
MRO
:Bill,
:If you're trying to retain original looks inside, then the dot mica caps are needed, and many are available from PTOP (http//www.oldradioparts.com)If not, then dip mica caps are available from many sources as noted below. Paper/foil/wax styles are usually replaced with newer versions. Some purists even remove the old cap and save the tubular enclosure, then put the new cap inside.
:marv
::After my last radio redo, I'm running low on caps. I used to pick them up at shows or buy from Everett Hoard in North Dakota - but he's been threatening to quit for years and I don't know if he's still in the business. Who currently has the best deals and good service? All recommendations welcomed. Thanks
You may want to check out Bob's Antique Radios & Electronics at http://www.radioantiques.com. He has electrolytics, polyester caps, pilot lamps and etc. at reasonable prices and so far has shipped quickly.
Try www.wjoe.com There is no minimum dollar amount to order.
