Thanks I will check him out. Most of the cone is gone and the more you touch it the worse it gets.
Jeff:
That looks like a plain ole PM speaker from what I can see. Is there something special about it or could you get a standard replacement from Radio Shack of someone?
Jeff,
I don't know what Lewis Linton was referring to - from the schematic it looks like your set has an electrodynamic speaker (not PM), so simply replacing with a new speaker from Radio Shack is really not an option. If you're not a stickler for originality, you could replace with a moderm PM speaker but you would have to add a choke in place of the speaker field coil. Myself, I prefer a set to look as original as possible and, if this is a nice radio you plan to keep, I'd opt for the repair by Hank Brazeal or other competent restorer. BTW - last time I checked, Radio Shack had dropped 99%+ of all replacement speakers. I bought several a few years back when they were closing them out...
OOps......
I kinda didn't notice that little choke in the power supply clearly labelled "Speaker Field"...you are very right and I am very much in the wrong direction with my thinking. Yes, you have a candidate for reconing, but you could temporarily replace the speaker field with a resistor and use a PM speaker to see if you need to be doing anything else while you wait for your speaker to be reconed. Also, my Hallicrafters has a PM speaker, so my thinking was biased.
