Majestic 92
9/6/2007 11:00:16 PMDoug
Hello,
Just inherited a Majestic 92 radio (model 90 receiver) and missing two g-45 tubes. Are they still available at a reasonable price?
Thanks!
9/7/2007 3:15:11 AMJohnnysan
:Hello,
:Just inherited a Majestic 92 radio (model 90 receiver) and missing two g-45 tubes. Are they still available at a reasonable price?
:Thanks!
Yes and no. Still available; price is un-reasonable.
9/7/2007 3:00:21 PMJon
::Hello,
::Just inherited a Majestic 92 radio (model 90 receiver) and missing two g-45 tubes. Are they still available at a reasonable price?
::Thanks!
:Yes and no. Still available; price is un-reasonable.
You do not have to locate the original Majestic G-45 tubes, any type 45 tube can be used and are available from many sources on the internet or ebay. Shop around for good used ones.They can be pricey. Often I pick up junker sets that are too far gone just for the tubes. Goo hunting.
Jon.
9/7/2007 3:23:03 PMNorm Leal
Doug
If you don't find 45's at a reasonable price contact Bill Turner. He sells subs for $20.
http://www.dialcover.com/tubes.html
You could also make your own with a different tube and adapter.
:::Hello,
:::Just inherited a Majestic 92 radio (model 90 receiver) and missing two g-45 tubes. Are they still available at a reasonable price?
:::Thanks!
::Yes and no. Still available; price is un-reasonable.
:You do not have to locate the original Majestic G-45 tubes, any type 45 tube can be used and are available from many sources on the internet or ebay. Shop around for good used ones.They can be pricey. Often I pick up junker sets that are too far gone just for the tubes. Goo hunting.
:Jon.
9/8/2007 11:23:30 PMThomas Dermody
1930s '45 tubes go for relatively cheap prices (G style tubes). G-45 tubes are very expensive.
Check eBay for regular '45 tubes, and if you want to make the set all original, save your pennies for some G-45 tubes. 2A3 tubes also sound really nice in the set. Be sure to replace the rubber on the speaker either with new rubber or suede. If the set sounds a bit harsh, I can give you the component values I used to build a negative feedback circuit for my set (two resistors and two capacitors...very easy).
