For smoother inter-referencing, since this schema is merely a tad wider than the page width of display and will only upset overall width a bit, I'm just going to tack it on the end . Since its being hosted off site, it will not present a hindrance to this sites B/W except for that instant while being called up and viewed, and even at that, it is only constituting of a mere 145K.
http://img521.imageshack.us/img521/9637/5intubedscopeschemayd2.gif
: I,m trying to restore a Millen Synchroscope that was built for the MIT radiation lab dated 4-30-45. There is no model # I can find on it except for serial #123. I've tried milleninfo@jamesmillenco.com to no avail. It has a 5" CRT and a 150vdc meter on the frt panel. It looks a lot like the RCA scopes of the time and uses Radiotrons: (1)5Z3,(1)6SL7,(1)6SJ7,(5)6SN7,(2)2X2 and I believe an EX905 CRT. There is a ceramic component with a single orange dot on it that appears to be an open resistor that comes off the plate of one of the 6SN7's. Does anyone have information on a schematic for this or possibly a similar RCA scope? Thanks, and I really appreciate this website lots.
With your supplied info, and comparing to the supplied schematic, looks like the possible equivalency of your 6SN7 could be assumed to be the the V5B section of the 12AU7 which goes on to feed the differential pair of deflection plate drivers of V6 A-B.
Your plate resistor being in the order of R46 a 10k resistor. Does the resistor that you found seem to be original, as that seems to be a high wattage rating for using for that positions application. Also see if that triode section is using a cathode resistor (R47 equivalent), and , if so, its value.
The specs on a 6SN7 have a cutoff on the plate dissipation at 1 watt, so no more than ~3 ma would be wanted flowing through that plate-cathode power loop (hopefully not experiencing your worst case 325 V mentioned...but they would like to see ~250Vdc on that tube, with a 300 V MAX spec. ) BUT, if you saw a cherry red plate...you DID exceed it with that opted choice of low value of plate resistor. After you do zero in on a final ? value of plate load resistor, put a series milliameter in line and see what current the circuit is then actually consuming.
Also, check the B+ supply line coming from the main B+ and see if it is initially dropped with a
feedline resistor somewhere in the line prior to the point where your "resistor" is supposed to be receiving its B+.
On this circuit, note that the B+ has been initially dropped down by R45 (3.9K). Also the cathode circuitry has R47(1K) in the power loop.
Also check your unit and see if that plate circuitry that you are working with is coupling into the deflection plate driver circuitry as you see this one doing with C28 (.1ufd).
You might compare this specific portion of circuitry to be roughly akin to a push- pull audio output circuit stage.
The preamp being on the left and the phase inverter being the next stage and the pair of outputs
being at the end. The difference, with the output transformer being replaced with a set of load resistors at R52-53, in order to have a varying voltage level developed across them to be fed on up to the H deflection plates. The interest there, being on more of a swinging electrostatic voltage rather than a swinging power level. Plus, there is a lot of DC coupling involved, since the precise DC aspect of the carried signal is equally of importance as the AC component. BUT FINALLY....... the signal handling in this circuitry is a recurrent sawtooth waveform rather than an audio signal !
ZUJ 'ing.....standing by
: Edd- I suspected that the open component was a wire-wound resistance/inductance, size-wise it looks around 5 watts,but I wasn't sure what value to plug in to the 6SN7 plate circuit. Orange is 3 but then again maybe not a value mark for this device. I tried a 150 ohm w/w resistor,but the plate of the tube began to glow red. I shutdown the scope and tacked in a 2k w/w resistor and got a wisp of a green trace on the screen(none before). It appears that it's working the horizontal circuit as that tube is on the same side of the scope as the horizontal controls. I'm going to try a 10k w/w resistor with a sliding tap so I can adjust and observe the results,it is a low voltage device(325v). The HV is there,but I dont have a measuring tool other than a sparkplug test indicator. Thanks for your help.
: Sir Edd- I mapped out the circuit around the 6SN7 (a picture always helps) to see where it comes from and where it goes and then decide what it does.It looks like it's the Horizontal Deflection Oscillator,between the sweep frequency selector switch RC network and the CRT plate drivers. The RCA receiving tube manual shows expected voltages and currents to be higher for oscillator duty than if it was class A amplifier duty for the 6SN7GTB and these coincide with voltmeter readings taken.I jumpered in a 10K plate resistor and measured 17.6 mA plate current (too high),then 33K of plate resistance brought it down to 7.7mA (more reasonable) Next I chipped into the(original) open plate resistor/inductor at where the leads entered the device and found my open at the point where the green powder fell out. I got to the remaining conductor end and measured 26K ohms. I now have a working sweeper although the trace isn't well centered(the horizontal position control is all the way to the right) and the Intensity control doesn't vary brightness very much. I may be looking at a HV issue but at least it's now working. Thanks for your ideas and schema to get me headed in the right direction. The belly of this thing is rather overwhelming if you try to take in the whole thing at once and not just focus on the stage requiring attention.
adouglas at gis.net
