:::I HAVE THIS RADIO THAT PLAYS AM SOME OF THE TIME AND THEN I GET NOTHING OR STATIC. THE FM ALWAYS WORKS.THE AM DID THIS ONCE BEFORE AND THEN IT STARTED TO PLAY FOR SEVERAL MONTHS AND NOW IT'S ACTING UP AGAIN.I WAS TOLD THAT THIS RADIO WILL DO THIS AT TIMES. IS THERE ANY SOLUTION TO THIS PROBLEM.
:::I think that if you use spray contact cleaner from Radio Shack it may clean the contacts in the switch, that solved a similar issue for me in the past, good luck, Dave F
HELLO DAVE,
I SPRAYED ONLY THE AM/FM SWITCH BUT IT STILL IS SOUNDS BAD. I SPRAYED THE TOP WHERE THE CONTACTS ARE. THE FM STATIONS ARE LOUD AND CLEAR.
