:Just picked up this meter for $5 - it has been bounced off the floor a few times with a couple of chips in the case back and a small chunk out of the lower rt front - but it works well. I think I can spiff up the damage with bondo or JB Weld. Anyone have info or possibly a manual on this meter that they could share? Thanks
:Correcting hot link below.... that was corrupted by a random picked up frontal colon....certainly thought that I was going to have to do a colon "ostomy" there for a minute !
::Speaking from the perspective of a person who has 6...or is it 7 now...of the units, I am somewhat enamored with them.
::A few of mine also had those typical case dingies and chips also. In which situation I initially dry fitted the pieces together to see if there were any pieces missing and then used automotive Bondo for the
::initial repair and then a thin wet coat of epoxy for filling any final micro voids or pinholes and then a #600 wet and dry sanding to accept a primer and then using final black Acrylic lacquer coats.
::With a final fine compounding....it / they looked much better than even when new.
::As for the schematic and op manual, this referencing to the readily available A version should fill the bill
::with the NA version additionally having the swish-across-switch at the bottom for range doubling.
::Tech Referencing................
::73's de Edd
:::Just picked up this meter for $5 - it has been bounced off the floor a few times with a couple of chips in the case back and a small chunk out of the lower rt front - but it works well. I think I can spiff up the damage with bondo or JB Weld. Anyone have info or possibly a manual on this meter that they could share? Thanks
