Here is one place you can find crystal set circuits.
http://www.crystalradio.net/
Crystal Set Society is here:
http://www.midnightscience.com./
:Can someone share a 1 coil schematic for a crystal radio? I have made several but need a new idea. Thanks
:Del
: Here is one place you can find crystal set circuits.
:http://www.crystalradio.net/
: Crystal Set Society is here:
:http://www.midnightscience.com./
::Can someone share a 1 coil schematic for a crystal radio? I have made several but need a new idea. Thanks
There isn't very many ways to make a different 1 coil crystal set. A single tuned coil doesn't separate stations very well. Try two. Double tuning will make a crystal set selective.
:Thanks. Got those already.
::Del
:: Here is one place you can find crystal set circuits.
::http://www.crystalradio.net/
:: Crystal Set Society is here:
::http://www.midnightscience.com./
:::Can someone share a 1 coil schematic for a crystal radio? I have made several but need a new idea. Thanks
:Del
: There isn't very many ways to make a different 1 coil crystal set. A single tuned coil doesn't separate stations very well. Try two. Double tuning will make a crystal set selective.
::Thanks. Got those already.
:::Del
::: Here is one place you can find crystal set circuits.
:::http://www.crystalradio.net/
::: Crystal Set Society is here:
:::http://www.midnightscience.com./
::::Can someone share a 1 coil schematic for a crystal radio? I have made several but need a new idea. Thanks
I would use two coils connected to different tuning cap sections. Between the two coils add a little capacity for coupling. It could be a few PF. A loop or two of wire wrapped around each coil can connected together will work.
Using a single coil with two tuned windings would be better than a single tuned circuit. The problem being most antenna coils don't have the same number of turns on primary and secondary windings.
:Norm,
:Is that like an antenna transformer with a primary and secondary both tuned with a dual gang tuner cap?
:If available, would a small antenna transformer work well?
:marv
::Del
:: There isn't very many ways to make a different 1 coil crystal set. A single tuned coil doesn't separate stations very well. Try two. Double tuning will make a crystal set selective.
:::Thanks. Got those already.
::::Del
:::: Here is one place you can find crystal set circuits.
::::http://www.crystalradio.net/
:::: Crystal Set Society is here:
::::http://www.midnightscience.com./
::::Norm
:::::Can someone share a 1 coil schematic for a crystal radio? I have made several but need a new idea. Thanks
http://www.schmarder.com
:Try this site:
:http://www.schmarder.com
