You can use a grid dip meter to tune the IFs, but adjusting them while outside of a radio would not do much good (IMO) because the circuit will change the frequency response. I doubt if a 10.7mHz IF transformer can be lowered to 9mHz easily; this is quite a drop.
But when returning the IF to the circuit you'll still need a bit of re-tweaking as things change when in-circuit.
Give me the existant pri and sec tuning cap values ....(if of different values)..... and I will come back with the additional capacitance required.
:Is it possible to tune IF transformers to frequency
:without having them in a set? I seem to recall that it can be done with a sig generator somehow.
:Also, I would like to retune small top and bottom slug tuned 10.7MC IF cans down to 9MC. What suggested capacitance in parallel with the existing internal caps would do the trick?
