If you have 1920's radios they were made for 110 volt operation; the additiona 8 to 12 volts is enough to make them run hot.
Leno: You can build a cheap voltage reducer to run your radios designed for 110v and 117v. I did this for some of mine, and seems to work great. You can find the parts list and circuit diagram at: http://bama.sbc.edu/voltagereducer.htm
Steve
I have a couple variations on the voltage reducer, altho the Bama site has a nice article and that is the more efficient design. I also include a 140 ohm neg temp coef thermister for a "soft" start. Bottom line, these
1930's radios are receiving about 112,113 volts altho the line voltage here is about 125. Just wondered if anyone else had given any serious thot to transformer temp. I also notice that the transformer in my Hallicrafters S-40a also runs about as warm on 110.
But I'm pretty sure those were run hard and continuously in real life. Just for add'l reference, I believe 140 degrees F is scalding and what you would regard as Hot water is about 120 degrees. 120 is typical temp for a lot of modern electrical gear.
Just curious. thanks
I suspect that at somewhat higher voltages that interstage gain is higher also. I've noticed quite a difference between even 105 and 115 volts when bringing
a set up slowly on a variac.
