losing B+
8/18/2007 5:56:26 PMCarl
I started with a battery radio that I could receive station weakly after changing the electrolytic and other capacitors, and now have next to nothing B+ voltage.
What would be the logical sequence in checking for this? Capacitors to ground first? Even A volatge is gone way down.
8/18/2007 6:42:52 PMDoug Criner
Carl: Did the radio work before you recapped it? If so, then I would suspect a wiring error.
I assume that the radio uses two separate batteries - an A and a B? It is strange that both voltages are low. Are the batteries good? If you're using a battery eliminator, a short on one voltage can drag the other one down too.
Doug
:I started with a battery radio that I could receive station weakly after changing the electrolytic and other capacitors, and now have next to nothing B+ voltage.
:What would be the logical sequence in checking for this? Capacitors to ground first? Even A volatge is gone way down.
8/19/2007 5:55:15 PMNorm Leal
Hi Carl
You must be operating the radio off AC line? That's the only way both A and B voltage will be low.
Measure voltage at the rectifier first. Follow it through to find out where voltage is lost. Check electrolytic caps. Be sure they aren't reversed and have a high enough voltage rating. Rectifier tube or selenium could be weak?
:Carl: Did the radio work before you recapped it? If so, then I would suspect a wiring error.
:I assume that the radio uses two separate batteries - an A and a B? It is strange that both voltages are low. Are the batteries good? If you're using a battery eliminator, a short on one voltage can drag the other one down too.
:Doug
::I started with a battery radio that I could receive station weakly after changing the electrolytic and other capacitors, and now have next to nothing B+ voltage.
::What would be the logical sequence in checking for this? Capacitors to ground first? Even A volatge is gone way down.
8/19/2007 10:44:22 PMCarl
Hello Norm,
Actually it is a battery set, I'm running B off an eliminator and A (2 volt tubes)off a storage battery with a dropping resistor. All capactors including the electrolytic have changed, at one point I was reading 80+ volts at the plates. I did clean the volume control at a subsequent point. Plates now run between 4 and 12 volts.
:Hi Carl
: You must be operating the radio off AC line? That's the only way both A and B voltage will be low.
: Measure voltage at the rectifier first. Follow it through to find out where voltage is lost. Check electrolytic caps. Be sure they aren't reversed and have a high enough voltage rating. Rectifier tube or selenium could be weak?
::Carl: Did the radio work before you recapped it? If so, then I would suspect a wiring error.
::I assume that the radio uses two separate batteries - an A and a B? It is strange that both voltages are low. Are the batteries good? If you're using a battery eliminator, a short on one voltage can drag the other one down too.
::Doug
:::I started with a battery radio that I could receive station weakly after changing the electrolytic and other capacitors, and now have next to nothing B+ voltage.
:::What would be the logical sequence in checking for this? Capacitors to ground first? Even A volatge is gone way down.
8/20/2007 10:16:07 AMNorm Leal
Carl
What voltage is coming from your B eliminator? It may have dropped off? Plate of your output tube is supplied through a transformer right to B+. This voltage should be just about the same as your supply.
What voltage do you read across your A dropping resistor. It may be getting hot and changing value?
:Hello Norm,
:Actually it is a battery set, I'm running B off an eliminator and A (2 volt tubes)off a storage battery with a dropping resistor. All capactors including the electrolytic have changed, at one point I was reading 80+ volts at the plates. I did clean the volume control at a subsequent point. Plates now run between 4 and 12 volts.
::Hi Carl
:: You must be operating the radio off AC line? That's the only way both A and B voltage will be low.
:: Measure voltage at the rectifier first. Follow it through to find out where voltage is lost. Check electrolytic caps. Be sure they aren't reversed and have a high enough voltage rating. Rectifier tube or selenium could be weak?
:::Carl: Did the radio work before you recapped it? If so, then I would suspect a wiring error.
:::I assume that the radio uses two separate batteries - an A and a B? It is strange that both voltages are low. Are the batteries good? If you're using a battery eliminator, a short on one voltage can drag the other one down too.
:::Doug
::::I started with a battery radio that I could receive station weakly after changing the electrolytic and other capacitors, and now have next to nothing B+ voltage.
::::What would be the logical sequence in checking for this? Capacitors to ground first? Even A volatge is gone way down.
8/20/2007 11:34:09 AMCarl
The eliminator is putting out 90 volts at its terminals, the plate on output tube currently shows about 20 volts. When I touch the probe to the B- terminal on the radio, I get negative 80 volts approximately.
:Carl
: What voltage is coming from your B eliminator? It may have dropped off? Plate of your output tube is supplied through a transformer right to B+. This voltage should be just about the same as your supply.
: What voltage do you read across your A dropping resistor. It may be getting hot and changing value?
::Hello Norm,
::Actually it is a battery set, I'm running B off an eliminator and A (2 volt tubes)off a storage battery with a dropping resistor. All capactors including the electrolytic have changed, at one point I was reading 80+ volts at the plates. I did clean the volume control at a subsequent point. Plates now run between 4 and 12 volts.
:::Hi Carl
::: You must be operating the radio off AC line? That's the only way both A and B voltage will be low.
::: Measure voltage at the rectifier first. Follow it through to find out where voltage is lost. Check electrolytic caps. Be sure they aren't reversed and have a high enough voltage rating. Rectifier tube or selenium could be weak?
::::Carl: Did the radio work before you recapped it? If so, then I would suspect a wiring error.
::::I assume that the radio uses two separate batteries - an A and a B? It is strange that both voltages are low. Are the batteries good? If you're using a battery eliminator, a short on one voltage can drag the other one down too.
::::Doug
:::::I started with a battery radio that I could receive station weakly after changing the electrolytic and other capacitors, and now have next to nothing B+ voltage.
:::::What would be the logical sequence in checking for this? Capacitors to ground first? Even A volatge is gone way down.
8/20/2007 6:49:53 PMDoug Criner
Carl, in order to follow your description, please link us to the schematic for this set.
When you say you read X volts when the voltmeter probe is on a certain point, tell us where the other probe is connected. Also, where the positive vs. negative probe is and whether the voltmeter is on the DC or AC scale.
:The eliminator is putting out 90 volts at its terminals, the plate on output tube currently shows about 20 volts. When I touch the probe to the B- terminal on the radio, I get negative 80 volts approximately.
::Carl
:: What voltage is coming from your B eliminator? It may have dropped off? Plate of your output tube is supplied through a transformer right to B+. This voltage should be just about the same as your supply.
:: What voltage do you read across your A dropping resistor. It may be getting hot and changing value?
:::Hello Norm,
:::Actually it is a battery set, I'm running B off an eliminator and A (2 volt tubes)off a storage battery with a dropping resistor. All capactors including the electrolytic have changed, at one point I was reading 80+ volts at the plates. I did clean the volume control at a subsequent point. Plates now run between 4 and 12 volts.
::::Hi Carl
:::: You must be operating the radio off AC line? That's the only way both A and B voltage will be low.
:::: Measure voltage at the rectifier first. Follow it through to find out where voltage is lost. Check electrolytic caps. Be sure they aren't reversed and have a high enough voltage rating. Rectifier tube or selenium could be weak?
::::Norm
:::::Carl: Did the radio work before you recapped it? If so, then I would suspect a wiring error.
:::::I assume that the radio uses two separate batteries - an A and a B? It is strange that both voltages are low. Are the batteries good? If you're using a battery eliminator, a short on one voltage can drag the other one down too.
:::::Doug
::::::I started with a battery radio that I could receive station weakly after changing the electrolytic and other capacitors, and now have next to nothing B+ voltage.
::::::What would be the logical sequence in checking for this? Capacitors to ground first? Even A volatge is gone way down.
8/20/2007 8:11:06 PMThomas Dermody
Measure the eliminator's voltage both before and after you connect it to the radio. You could either have a problem in the radio, or in the eliminator. Make sure that the polarities of your electrolytics are correct. Otherwise there may be a failing component in the eliminator.
8/24/2007 4:36:41 PMCarl
Thanks to all who assisted me on the back burner. What happened was a defective open switch between B minus and chassis (i.e. lack of B voltage). Also, a defective modern alligator clip wire which gave me intermittent A voltage. Thanks again.
:Measure the eliminator's voltage both before and after you connect it to the radio. You could either have a problem in the radio, or in the eliminator. Make sure that the polarities of your electrolytics are correct. Otherwise there may be a failing component in the eliminator.
:T.
