Does the radio operate? If not your 42 tube is probably not drawing current. Try another 42 tube. This tube draws most of the current in a Philco 625 radio which should load down B+ voltage.
Recapping a radio and high line voltage can also cause voltages to be high.
http://www.nostalgiaair.org/PagesByModel/810/M0013810.pdf
:I have 300 volts at the plates that should be at 258.
:I am kinda stuck on what I should replace. any ideas?
:it has been recapped completely.
:Hi
: Does the radio operate? If not your 42 tube is probably not drawing current. Try another 42 tube. This tube draws most of the current in a Philco 625 radio which should load down B+ voltage.
: Recapping a radio and high line voltage can also cause voltages to be high.
:http://www.nostalgiaair.org/PagesByModel/810/M0013810.pdf
::I have 300 volts at the plates that should be at 258.
::I am kinda stuck on what I should replace. any ideas?
::it has been recapped completely.
Also, did someone possibly replace the power transformer? What is its B voltage?
