4 Tube Radio With Empire Logo
8/5/2007 8:41:38 AMGreg
I just acquired an old Empire 4 tube AC radio. The tube line up is 12Z3, 6C6, 38, 6D6. The radio is blonde colored wood with black wood trim. There are 2 dial plates and no lights. This radio looks very 1930's deco. Is there anyone out there that might know anything about this radio? I have no model number to go by and I cant seem to find anything that matches it.
Greg
8/5/2007 10:16:47 AMNorm Leal
Hi Greg
Empire was made by Fada. Mallory lists the radio as Fada Model #110A or 110B.
:Hi,
:I just acquired an old Empire 4 tube AC radio. The tube line up is 12Z3, 6C6, 38, 6D6. The radio is blonde colored wood with black wood trim. There are 2 dial plates and no lights. This radio looks very 1930's deco. Is there anyone out there that might know anything about this radio? I have no model number to go by and I cant seem to find anything that matches it.
:Thanks
:Greg
8/5/2007 10:38:16 AMGreg
Hi Norm,
Many thanks!
Greg :)
:Hi Greg
: Empire was made by Fada. Mallory lists the radio as Fada Model #110A or 110B.
::Hi,
::I just acquired an old Empire 4 tube AC radio. The tube line up is 12Z3, 6C6, 38, 6D6. The radio is blonde colored wood with black wood trim. There are 2 dial plates and no lights. This radio looks very 1930's deco. Is there anyone out there that might know anything about this radio? I have no model number to go by and I cant seem to find anything that matches it.
::Thanks
::Greg
8/5/2007 10:42:34 AMGreg
Any chance you would know were I could find a schematic? I didnt see one in the Schematics section of this site.
Greg
:Hi Norm,
:Many thanks!
:Greg :)
::Hi Greg
:: Empire was made by Fada. Mallory lists the radio as Fada Model #110A or 110B.
:::Hi,
:::I just acquired an old Empire 4 tube AC radio. The tube line up is 12Z3, 6C6, 38, 6D6. The radio is blonde colored wood with black wood trim. There are 2 dial plates and no lights. This radio looks very 1930's deco. Is there anyone out there that might know anything about this radio? I have no model number to go by and I cant seem to find anything that matches it.
:::Thanks
:::Greg
8/5/2007 11:34:29 AMCarl T
:Any chance you would know were I could find a schematic? I didnt see one in the Schematics section of this site.
:Thanks
:Greg
Hi Greg,
You might try Dewald 430 or Sears 7173/7183 schematics.
Carl T
8/18/2007 7:30:57 PMGreg
I am currently re-capping this radio using the Dewald 430 schematic. I've found there is a 275 ohm resistor wire built into the original cord. Can someone tell me if its ok to replace the cord and add a wirewound resistor on the heater line of this circuit?
Greg
:Hi Greg,
:You might try Dewald 430 or Sears 7173/7183 schematics.
:Carl T
8/19/2007 5:49:13 PMNorm Leal
Ho Greg
Yes you can use a wire wound resistor but there are a couple problems. Where will it mount? The resistor will be very hot. How will you dissipate the heat?
There are alternatives. Read this first:
http://www.vintage-radio.com/repair-restore-information/valve_dropper-calcs.html
:Hi,
:I am currently re-capping this radio using the Dewald 430 schematic. I've found there is a 275 ohm resistor wire built into the original cord. Can someone tell me if its ok to replace the cord and add a wirewound resistor on the heater line of this circuit?
:Thanks
:Greg
::Hi Greg,
::You might try Dewald 430 or Sears 7173/7183 schematics.
::Carl T
