:What is the best spray for contact switches - like band pushbuttons and wafer switches - DeoxIT, LPS, etc.??? Also, what seems to work best as a pot cleaner and lube - I've used a variety of products in the past and none seem to stand out. Any strong opinions out there?
For exposed contacts, such as on a rotary switch, Brasso on a Q-tip or piece of stiff card stock can help polish off black corrosion.
I very much like di-electric grease on potentiometer carbon elements (volume control, tone control, etc.). Its corrective action is long lasting, and doesn't foul things up like WD-40, which sprays all over everything, and is especially susceptable to leakage paths in volume controls and similar controls, because bits of carbon get into the film eventually.
Bill VA
Bill VA
:Bill,
:For contacts, I use the "Silver Dipping solution for silverware and jewelry, available at most grocery or drug stores. A clean Q-Tip or thin card stock wrapped in soft cloth can be dipped in the solution, and applied directly to the contact(s). Distilled or deionized water with the same tools is used to wipe the cleaned area of residual cleaning agent. For pots I use a quick soak in denatured alcohol, and pressurized air. I found that even the alcohol will remove some of the element"s carbon deposit if vigorous wiping is used. The dielectric (silicon) grease is a good lubricant, but really requires dissassembly for good application, otherwise high quality sprays are available. Some older sets have graphite elements vs carbon, which are very difficult to clean, and in most cases, impossible to repair. I was successful in creating an entire new element with powdered graphite from the hardware store, but this task is not for the faint of heart.
:marv
::What is the best spray for contact switches - like band pushbuttons and wafer switches - DeoxIT, LPS, etc.??? Also, what seems to work best as a pot cleaner and lube - I've used a variety of products in the past and none seem to stand out. Any strong opinions out there?
Hi, I was in the electronic service business for 28 years and used Caig
DeoxIT D5 for many of those years without any problems. For switches and pots, a couple of squirts a few rotations and fixed. I have a new can labeled GC DE-OX-ID and it appears to contain the same chemicals. The nice thing about the chemicals is that any over spray does not damage other parts.
Wm.
