RCA14X help needed
7/30/2007 5:37:57 AMMeyer Rochwerger
Recently I bought a RCA 14X radio at ebay that's in good overall conditions.
After a good cleaning, I did recap it and it works fine in the MW band.
(I did not change the mica caps). But... nothing at SW.
I made some measures and found that it's not oscillating.
The grid (pin 5) reads 0 volts in SW and aproximately -6V in MW.
The AVC and +B voltages are normal.
I have another set with this same problem.
Any sugestion will be wellcome.
Meyer
7/30/2007 6:31:32 AMJim Mann
Meyer,
If you haven't done it as part of the cleaning, try cleaning the bandswitch contacts. Also, check the value of R1. Sometimes just trying a different tube will work.
Jim
7/30/2007 5:56:50 PMMeyer
:Meyer,
:If you haven't done it as part of the cleaning, try cleaning the bandswitch contacts. Also, check the value of R1. Sometimes just trying a different tube will work.
:Jim
7/30/2007 6:01:39 PMMeyer
::Meyer,
::If you haven't done it as part of the cleaning, try cleaning the bandswitch contacts. Also, check the value of R1. Sometimes just trying a different tube will work.
::Jim
Hello Jim,
I allready cleaned the band switch, and ordered a new converter (12SA7). Meanwhile I'll check the value of R1 and then I'll give you a feedback.
Meyer
7/30/2007 7:57:41 PMMeyer
:::Meyer,
:::If you haven't done it as part of the cleaning, try cleaning the bandswitch contacts. Also, check the value of R1. Sometimes just trying a different tube will work.
:::Jim
:Hello Jim,
:I allready cleaned the band switch, and ordered a new converter (12SA7). Meanwhile I'll check the value of R1 and then I'll give you a feedback.
:Thanks,
:Meyer
I've found R1 with 31k and replaced it by a new one 22k. I replace the two capacitors involved in the oscillating circuit C24(56pf) and C26(150pf). I try a few used 12SA7 tubes from my junk box and found one that gives a small negative voltage in the grid (5). The MW still working good, but with the SW I can pick some stations with scratchy sound. I think that the cure is a new converter tube. So, I'll wait till it cames to give you a definitive feedback (I hope).
Meyer
8/4/2009 9:12:39 PMGary W. Prutchick
Hi Meyer,
Have you checked the alignment?
Gary
::::Meyer,
::::If you haven't done it as part of the cleaning, try cleaning the bandswitch contacts. Also, check the value of R1. Sometimes just trying a different tube will work.
::::Jim
::Hello Jim,
::I allready cleaned the band switch, and ordered a new converter (12SA7). Meanwhile I'll check the value of R1 and then I'll give you a feedback.
::Thanks,
::Meyer
:I've found R1 with 31k and replaced it by a new one 22k. I replace the two capacitors involved in the oscillating circuit C24(56pf) and C26(150pf). I try a few used 12SA7 tubes from my junk box and found one that gives a small negative voltage in the grid (5). The MW still working good, but with the SW I can pick some stations with scratchy sound. I think that the cure is a new converter tube. So, I'll wait till it cames to give you a definitive feedback (I hope).
:Meyer
8/4/2009 8:16:41 PMAlessandro
Meyer boa noite, preciso entrar em contao com vc, tem algum email para nos conversarmos, é spbre restauração. Grato
