I cannot find any info on the M80F tube. The heater is burned out, so this project is going nowhere unless there is a suitable replacement. Suggestions appreciated.
I'll try to post some photos here:
Case
http://aycu02.webshots.com/image/24121/2004178274511448646_rs.jpg
Chassis Back
http://aycu18.webshots.com/image/24097/2004166068951685620_rs.jpg
Chassis Top
http://aycu33.webshots.com/image/21432/2004198039036009526_rs.jpg
Tube
http://aycu37.webshots.com/image/22036/2004121934433716728_rs.jpg
Case
[URL=http://allyoucanupload.webshots.com/v/2004178274511448646][IMG]http://aycu02.webshots.com/ima
ge/24121/2004178274511448646_th.jpg[/IMG][/URL]
Chassis Back
[URL=http://allyoucanupload.webshots.com/v/2004166068951685620][IMG]http://aycu18.webshots.com/ima
ge/24097/2004166068951685620_th.jpg[/IMG][/URL]
Chassis Top
[URL=http://allyoucanupload.webshots.com/v/2004198039036009526][IMG]http://aycu33.webshots.com/ima
ge/21432/2004198039036009526_th.jpg[/IMG][/URL]
Tube
ge/21432/2004198039036009526_rs.jpg[/IMG][/URL]
I was able to view your photo. Your M80F is a ballast tube. It will be wired in series with tube filaments and acts as a dropping resistor. In operation it will be very hot.
M80F is rated to drop 80 volts @ 300 ma. According to the book it has two resistors built in. One between pins 2 and 3 and the other between 7 and 8. As long as you have resistance readings between these pins the tube is good.
:I'll try the photos again:
:Case
:[URL=http://allyoucanupload.webshots.com/v/2004178274511448646][IMG]http://aycu02.webshots.com/ima
:ge/24121/2004178274511448646_th.jpg[/IMG][/URL]
:Chassis Back
:[URL=http://allyoucanupload.webshots.com/v/2004166068951685620][IMG]http://aycu18.webshots.com/ima
:ge/24097/2004166068951685620_th.jpg[/IMG][/URL]
:Chassis Top
:[URL=http://allyoucanupload.webshots.com/v/2004198039036009526][IMG]http://aycu33.webshots.com/ima
:ge/21432/2004198039036009526_th.jpg[/IMG][/URL]
:Tube
:ge/21432/2004198039036009526_rs.jpg[/IMG][/URL]
Rob,
I believe your radio may be a model 214:
http://www.nostalgiaair.org/PagesByModel/302/M0000302.pdf
Carl T
:I'm working on Air-King from the late 1930's. It seems to be a Model 21, but the tube types do not match the schematic available on Nostalgia Air. Here is what is in the radio:
:6D6 (Six Pins)
:6c6 (Six Pins)
:25A7G (Octal)
:M80F (Octal, Made in USA by Hytron)
:I cannot find any info on the M80F tube. The heater is burned out, so this project is going nowhere unless there is a suitable replacement. Suggestions appreciated.
:I'll try to post some photos here:
:Case
:http://aycu02.webshots.com/image/24121/2004178274511448646_rs.jpg
:Chassis Back
:http://aycu18.webshots.com/image/24097/2004166068951685620_rs.jpg
:Chassis Top
:http://aycu33.webshots.com/image/21432/2004198039036009526_rs.jpg
:Tube
:http://aycu37.webshots.com/image/22036/2004121934433716728_rs.jpg
