That's exactly what it is. A cathode follower driving a pentode output stage. This was done to save a cathode resistor and bypass cap. A 6B5 can be replaced by 42 tube if a 470 ohm resistor is added in series with pin 5. Resistor should be bypassed with an electrolytic cap.
Basing is 6AS. You will notice there is a resistor built in connected to the cathode of follower stage. It's not shown on the Silvertone schematic. If this resistor opens and there is internal leakage the tube runs away with current. You can't replace the resistor.
http://www.mif.pg.gda.pl/homepages/frank/sheets/121/6/6B5.pdf
Another tube like this is 6N6. It also can be replaced by 6F6 or similar with bias added.
:I'm looking at the 6B5 output section of this Silvertone 4463 model. http://www.nostalgiaair.org/PagesByModel/051/M0017051.pdf
:I have not seen this arrangement before.
:The triode on the left has it's cathode wired directly to the grid of the trio on the right.
:Looks like the left triode is driving the right triode with what seems to be a "cathode follower" arrangement... is that right?
:Can Norm or one of you other more knowledgeable guys enlighten me a little on why this arrangement was used and what the particular benefits may be?
It's a triode cathode follower driving a triode output tube (not pentode). That's the way it's shown in most books. Noticed Sylvania added another grid in their spec. Most books show it as a dual triode.
:Peter
: That's exactly what it is. A cathode follower driving a pentode output stage. This was done to save a cathode resistor and bypass cap. A 6B5 can be replaced by 42 tube if a 470 ohm resistor is added in series with pin 5. Resistor should be bypassed with an electrolytic cap.
: Basing is 6AS. You will notice there is a resistor built in connected to the cathode of follower stage. It's not shown on the Silvertone schematic. If this resistor opens and there is internal leakage the tube runs away with current. You can't replace the resistor.
: http://www.mif.pg.gda.pl/homepages/frank/sheets/121/6/6B5.pdf
: Another tube like this is 6N6. It also can be replaced by 6F6 or similar with bias added.
::I'm looking at the 6B5 output section of this Silvertone 4463 model. http://www.nostalgiaair.org/PagesByModel/051/M0017051.pdf
::I have not seen this arrangement before.
::The triode on the left has it's cathode wired directly to the grid of the trio on the right.
::Looks like the left triode is driving the right triode with what seems to be a "cathode follower" arrangement... is that right?
::Can Norm or one of you other more knowledgeable guys enlighten me a little on why this arrangement was used and what the particular benefits may be?
A cathode follower gives current gain but not voltage. Not needed in most radio circuits. It's used when current is needed to drive a circuit. The second triode is operated with zero bias, grid can go positive. Under this condition grid current will be drawn by the tube.
:Thanks very much Norm
:... but I was wondering why cathode follower is not otherwise used often/ever...in Radio audio amps.... and what the salient features were that were enough to incorporate them here.
A cathode follower circuit was used sometimes to drive a low impedance line between two pieces of equipment that are separated by some distance. A cathode follower uses 100 percent feedback so it has very low distortion and a very good bandwidth. It also has a higher input impedance than other standard amplifier circuits so there is almost no loading of the circuit preceding it.
I re-coned the speaker, but I haven't re-capped the chassis. The audio has a lot of distortion. I really want to hear what it will sound like. Since I obtained the radio, I've bought a couple of 6B5s and 6N6s. I've used the 6N6s in some radios I own that use 6K6s or 6F6s. They sound pretty nice, though you must short out the cathode bias normally used by the 6F6 or 6K6, or else you won't get much power (6B5 and 6N6 don't need cathode biasing).
