525-7 is the Sams number. This is an X100 there is no A, B or C on it. It's the original X100. I'm not sure if that SAMs has the original X100 in it.
Probably a different cap value? High frequency response is reduced by caps from the signal line to B+ or ground. Sometimes there is a cap across the output transformer. Be sure one isn't too large. It's easy to be a decade off in cap values. One marked 103 is .01 mf, 104 is .1 mf.
:Hello All,
: This is about the Fisher I mentioned in another posting. One of the channels isn't capable of the same high frequencies as the other. What do you recommend I look at? I wont rule out that I may have made a mistake with a capacitor value either. But I think it may be a disc capacitor problem.
:Thanks,
:Dave
:525-7 is the Sams number. This is an X100 there is no A, B or C on it. It's the original X100. I'm not sure if that SAMs has the original X100 in it.
MRO
:Dave
: Probably a different cap value? High frequency response is reduced by caps from the signal line to B+ or ground. Sometimes there is a cap across the output transformer. Be sure one isn't too large. It's easy to be a decade off in cap values. One marked 103 is .01 mf, 104 is .1 mf.
::Hello All,
:: This is about the Fisher I mentioned in another posting. One of the channels isn't capable of the same high frequencies as the other. What do you recommend I look at? I wont rule out that I may have made a mistake with a capacitor value either. But I think it may be a disc capacitor problem.
::Thanks,
::Dave
::525-7 is the Sams number. This is an X100 there is no A, B or C on it. It's the original X100. I'm not sure if that SAMs has the original X100 in it.
:Try swapping the speakers...maybe your tweeter has lost its' cherp.
:MRO
::Dave
:: Probably a different cap value? High frequency response is reduced by caps from the signal line to B+ or ground. Sometimes there is a cap across the output transformer. Be sure one isn't too large. It's easy to be a decade off in cap values. One marked 103 is .01 mf, 104 is .1 mf.
:::Hello All,
::: This is about the Fisher I mentioned in another posting. One of the channels isn't capable of the same high frequencies as the other. What do you recommend I look at? I wont rule out that I may have made a mistake with a capacitor value either. But I think it may be a disc capacitor problem.
:::Thanks,
:::Dave
:::525-7 is the Sams number. This is an X100 there is no A, B or C on it. It's the original X100. I'm not sure if that SAMs has the original X100 in it.
:Dave
::Hello All,
::Thanks,
::Dave
