Dummy Tubes
7/24/2007 4:23:57 PMBill VA
Anybody have some tubes like these?
7/24/2007 4:44:33 PMNorm Leal
Bill
No nothing like that. Noticed they say "souvenir" and have a date. Anything special about the date? Could it be open house at GE?
Wonder if they are regular vacuum tubes? Would be interesting to check continuity between pins #2 and #7.
I have some semiconductors marked "mechannical sample" but there is something inside.
:Anybody have some tubes like these?
7/24/2007 6:42:02 PMDoug Criner
A couple of theories present themselves.
1. Maybe they were rejects, labeled souvenier? If there is heater continuity, then maybe that's what they are.
2. Maybe they are empty - just a base, pins, and metal envelope?
Doug
:Bill
: No nothing like that. Noticed they say "souvenir" and have a date. Anything special about the date? Could it be open house at GE?
: Wonder if they are regular vacuum tubes? Would be interesting to check continuity between pins #2 and #7.
: I have some semiconductors marked "mechannical sample" but there is something inside.
::Anybody have some tubes like these?
7/24/2007 8:45:24 PMBill VA
Well my picture wasn't as I thought. One rolled. But here's the print:
MID-WINTER HAM REUNION
OARS-TARS FEB29, 1948
SOUVENIR DUMMY TUBE
GENERAL ELECTRIC CO.
OWENSBORO TUBE WORKS
One tube is stamped 6SR7 in metal on the base of the envelope and the other one is a 6SG7. The 6SR7 tested ok but the 6SG7 has a short beween Filament and cathode. Tubes came from a deceased Ham. I don't know where the reunion was held.
Bill VA and trying to center some text?
:A couple of theories present themselves.
:1. Maybe they were rejects, labeled souvenier? If there is heater continuity, then maybe that's what they are.
:2. Maybe they are empty - just a base, pins, and metal envelope?
:Doug
::Bill
:: No nothing like that. Noticed they say "souvenir" and have a date. Anything special about the date? Could it be open house at GE?
:: Wonder if they are regular vacuum tubes? Would be interesting to check continuity between pins #2 and #7.
:: I have some semiconductors marked "mechannical sample" but there is something inside.
:::Anybody have some tubes like these?
7/28/2007 2:41:14 PMBill
Bill,
Those are unique collectables! In that you are able to test the tubes certainly indicates that they are not empty - likely they were QC rejects. You might try contacting George Fathauer - a big tube collector and seller - for more info...(http://www.users.qwest.net/~tubes/)
:Well my picture wasn't as I thought. One rolled. But here's the print:
SOUVENIR DUMMY TUBE
:One tube is stamped 6SR7 in metal on the base of the envelope and the other one is a 6SG7. The 6SR7 tested ok but the 6SG7 has a short beween Filament and cathode. Tubes came from a deceased Ham. I don't know where the reunion was held.
:Bill VA and trying to center some text?
::A couple of theories present themselves.
::1. Maybe they were rejects, labeled souvenier? If there is heater continuity, then maybe that's what they are.
::2. Maybe they are empty - just a base, pins, and metal envelope?
::Doug
:::Bill
::: No nothing like that. Noticed they say "souvenir" and have a date. Anything special about the date? Could it be open house at GE?
::: Wonder if they are regular vacuum tubes? Would be interesting to check continuity between pins #2 and #7.
::: I have some semiconductors marked "mechannical sample" but there is something inside.
::::Anybody have some tubes like these?
7/29/2007 2:48:20 PMBill VA
Thanks Bill. I'll check the site.
Bill VA
:Bill,
:Those are unique collectables! In that you are able to test the tubes certainly indicates that they are not empty - likely they were QC rejects. You might try contacting George Fathauer - a big tube collector and seller - for more info...(http://www.users.qwest.net/~tubes/)
::Well my picture wasn't as I thought. One rolled. But here's the print:
SOUVENIR DUMMY TUBE
::One tube is stamped 6SR7 in metal on the base of the envelope and the other one is a 6SG7. The 6SR7 tested ok but the 6SG7 has a short beween Filament and cathode. Tubes came from a deceased Ham. I don't know where the reunion was held.
::Bill VA and trying to center some text?
:::A couple of theories present themselves.
:::1. Maybe they were rejects, labeled souvenier? If there is heater continuity, then maybe that's what they are.
:::2. Maybe they are empty - just a base, pins, and metal envelope?
:::Doug
::::Bill
:::: No nothing like that. Noticed they say "souvenir" and have a date. Anything special about the date? Could it be open house at GE?
:::: Wonder if they are regular vacuum tubes? Would be interesting to check continuity between pins #2 and #7.
:::: I have some semiconductors marked "mechannical sample" but there is something inside.
::::Norm
:::::Anybody have some tubes like these?
