Testing
7/17/2007 10:39:39 PMLewis Linson
I'm trying to figure out how y'all are inserting things into your posts. Here's my first try:
www.gifs.net-Animation11/webdesign_Elements-Lines-light_switch.gif
Did it work?
7/17/2007 10:40:18 PMLewis Linson
:I'm trying to figure out how y'all are inserting things into your posts. Here's my first try:
:www.gifs.net-Animation11/webdesign_Elements-Lines-light_switch.gif
:Did it work?
Nope
7/17/2007 10:43:05 PMLewis Linson
::I'm trying to figure out how y'all are inserting things into your posts. Here's my first try:
::Did it work?
:Nope
7/17/2007 10:56:41 PMPeter G Balazsy
Lewis:
I think you put in a ''dash'' instead of an underscore in the light_switch.gif part:
I'll try it here for you:
7/17/2007 11:01:16 PMPeter G Balazsy
:Lewis:
:I think you put in a ''dash'' instead of an underscore in the light_switch.gif part:
:I'll try it here for you:
Once again?
7/17/2007 11:15:39 PMRadiodoc
Peter,
You got it typed in right. Lewis needs to use:
http://www.gifs.net/Animation11/Webdesign_Elements/Lines/light_switch.gif
::Lewis:
::I think you put in a ''dash'' instead of an underscore in the light_switch.gif part:
::I'll try it here for you:
:Once again?
7/17/2007 11:45:07 PMLewis Linson
:Peter,
:You got it typed in right. Lewis needs to use:
:http://www.gifs.net/Animation11/Webdesign_Elements/Lines/light_switch.gif
:Radiodoc
:::Lewis:
:::I think you put in a ''dash'' instead of an underscore in the light_switch.gif part:
:::I'll try it here for you:
::Once again?
7/17/2007 11:47:52 PMLewis Linson
::Peter,
::You got it typed in right. Lewis needs to use:
::http://www.gifs.net/Animation11/Webdesign_Elements/Lines/light_switch.gif
::Radiodoc
::::Lewis:
::::I think you put in a ''dash'' instead of an underscore in the light_switch.gif part:
::::I'll try it here for you:
:::Once again?
:Now that I know what to type, do I put it in "notepad" or something and copy and past into my post?? At least I can draw the schematic for it.
7/17/2007 11:52:30 PMPeter G Balazsy
Ye Lewis.. It's always best to try it all in notepad first and test it by saving it as an html file and opening it for testing and editing in with your browser...
go to file open... then browse to the file.
De-bugging in notepad and using your browser to test display...saves many little oversights
7/18/2007 12:19:39 AMLewis Linson
Saved from "notepad". Do it work?
7/18/2007 12:21:29 AMLewis Linson
Knowlege is wonderful, but know just enough to be dangerous is the most fun of all!!
