You will need to sand your patches after they have hardened, so that they are flush with the rest of the radio. The radio will also have to be painted, because the J-B Weld will most likely not match the bakelite. I have never tried dying J-B Weld. There are some things that I want to make with it that require colors, so I will try with various oil paints. I don't know what it is compatible with, or what will ruin the catalyst action.
For broken screw holes, I obtain long screws with the same thread as the originals (or what I intend to use). Then I oil them with a thin film of oil, and screw them into the remains of the screw holes. I take any kind of tape (masking or celophane) and form it to the general shape of the bakelite where the screw hole was drilled. Then I gently place J-B Weld into the space formed by the tape, with a tool such as a toothpick. A day later, once the J-B Weld hardens, I remove the tape and the screw, and the screw hole is now ready for use.
::Any ideas on fixing cracks or replacing missing pieces on bakelite radio cabinets. I use windex to clean the cabinets and then use a dark furniture polish to restore its original luster.
:: You may try placing all of the pieces together at the same time and using rubber bands as the clamp.
:then apply moderate amounts of super glue from inside the cabinet and allowing the capillary action to carry it into the cracks. there can be gaps in the surface. This takes you so far. Someone else here may know if there are products to match color short of repainting.
Rub it like you are compounding your car.
It is wonderful.
At the end ...buff with very fast strokes with a very soft clean cloth like Tee shirt and it'll gleam.
:A dull aged Bakelite cabinet can be restored to near perfect with Brasso. But use it like you mean it. Not just a lick 'n promise.
:Rub it like you are compounding your car.
:It is wonderful.
:At the end ...buff with very fast strokes with a very soft clean cloth like Tee shirt and it'll gleam.
That may work ... I'd like to see...it done.
I guess if you make a real thick slurry.
I've seen that concept work with other things like saw-dust and glue for wood repair and brick-dust with mortar for brick repair.
